I Have A Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2011, 10:19 PM   #1
I have a question
I have a question for you all. Had a slow draining toilet upstairs and in the basement, the upstairs was the worst. I took off upstairs toilet and snaked drain. Snaked the roof vent, snaked building drain from the clean out in the basement, some roots came back with the snake(about a handful) reamed out under rim holes in toilet. After all this it still drains slowly. Any ideas?!
mike honcho is offline   Reply With Quote
Old 12-11-2011, 10:30 PM   #2
An old Tradesmen
Rewards Points: 6,116
Made this its own thread.
Old 12-11-2011, 10:50 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
something stuck in trap of toilet?
plummen is offline   Reply With Quote
Old 12-11-2011, 11:06 PM   #4
Lightbulb
I will check that next, I will try renting a toilet snake.
Old 12-11-2011, 11:13 PM   #5
plummen's Avatar
you can buy a decent closet auger at ace hardware for around $20.00
The Following User Says Thank You to plummen For This Useful Post:
mike honcho (12-11-2011)
Old 12-12-2011, 09:03 AM   #6
Rewards Points: 150
The last time I had something stuck in the trap (bottle of nail polish) I had pull the stool and use a garden hose to reverse flush from the botom.
josall is offline   Reply With Quote
Old 12-12-2011, 10:04 AM   #7
DIY staff
Rewards Points: 7,174
I put my money on a slow main drain to the street---re connect that upstairs toilet---get someone to flush that one while you have water running in the tub --sink and anything else you can turn on--
Flood the system---see if the main can handle it--the basement toilet hole should over flow if the main is draining slow---
Old 12-12-2011, 10:28 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
mike honcho: "some roots came back with the snake"
Does this suggest anything to anyone?
Old 12-12-2011, 10:33 AM   #9
DIY staff
Morning Bud---That's what gave me a clue,too.
Bud Cline (12-12-2011)
Old 12-13-2011, 03:20 PM   #10
Ok I'll get the homeowner to try that one. The only noticeable problem was a slow toilet upstairs and in the basement the toilets a bit slow. The main floor is fine.
First I'll try snaking the toilet s trap then if that doesn't work flood the system, If it's not the main building drain draining slow then replace toilet to correct the slow draining toilet?
Old 12-13-2011, 03:56 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 352
Tooth brushes and the like are difficult to remove with an auger- you think its clear and then paper hangs up.... back to square one.
Pull the toilet, run the auger through the trap, tape on a big rag and pull it back with the auger.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
