I Have A Leak In A 7 Inch Pipe Running From My Kitchen To My Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2010, 04:39 PM   #1
I have a leak in a 7 inch pipe running from my kitchen to my bathroom
I have a small leak from the pipe running from my kitchen to my bathroom i think its a main drain pipe it is 7 inches in diameter, only leaks when it's draining. I have removed the bathroom vanity and cut away the drywall to expose the pipe it's pretty rusted and i don't think I have a wrench big enough to remove it. HELP
sully2310 is offline   Reply With Quote
Old 05-22-2010, 11:02 PM   #2
Do something
D'Brie's Avatar
Is the pipe cast iron? If so, you'll need to support it, cut the bad section out, replace with ABS pipe using Mission or Fernco bands. You really may want a licenced plumber to do it. Best of luck. Oh, if you are going to cut the pipe yourself, use a snap cutter or sawzall with abrasive blades. A licenced plumber will have these tools.
D'Brie is offline   Reply With Quote
Old 05-23-2010, 08:10 AM   #3
Leak Master
7 inch pipe . Sounds like something a pro might need to look at.
O'Leaky is offline   Reply With Quote
Old 05-23-2010, 10:23 AM   #4
Licensed Master Plumber
it ain't 7", they don't make 7" anything. It's probably 4" cast and you will need a licensed plumber to fix this one
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Lowering kitchen drain pipe - PVC LeviDIY Plumbing 22 08-21-2016 04:23 PM
Installing bathroom sink - drains off slightly less than pipe diameter lazzlazz Plumbing 17 05-21-2010 05:12 PM
Leak found - need advice (Vent pipe) krooser78 Plumbing 0 03-29-2010 02:49 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
