I Have Drain Flies - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-19-2010, 09:09 PM   #1
I have drain flies
I think it may have to do with the remodeling i did prior to having this problem. There seems to be grout collected in the drain. how do i clean out the drain to keep from getting the flies.
ivernon is offline   Reply With Quote
Old 11-19-2010, 09:12 PM   #2
get a drain spider? use a shopvac and something like a screwdriver... should get most of it if it's collected in the trap
the_man is offline   Reply With Quote
Old 11-21-2010, 06:24 AM   #3
Picky Plumber
Uhhhhhhhhh.... did you put a trap in the drain for your shower?
Plumber26 is offline   Reply With Quote
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Drain flies under house fly slayer Plumbing 1 06-03-2009 11:35 AM
Drain Flies - Help! mcstan Pest Control 4 05-10-2009 03:31 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
