I Got Flash And Bang Nois From Wall 24 Hours -every After 15 Minuts. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2012, 08:13 PM   #1
I got flash and bang nois from wall 24 hours -every after 15 minuts.
When we are not using any water or anything - still we hear nois . Do u have idea what is it ?
fhaque is offline   Reply With Quote
Old 01-26-2012, 08:29 PM   #2
jproffer's Avatar
Rewards Points: 716
Water hammer, but that is usually when you turn off a faucet.
HVAC ductwork banging from expansion/contraction....??
What do you "flashing"?? You mean sparking?? Like electricity?
jproffer is offline   Reply With Quote
Old 01-26-2012, 08:35 PM   #3
Flashing nois
No, While I am not doing anything or even sleeping still I hear flashing and banging nois every after 15 minuts . I checked all washrooms and faucet but no water leaking . nois coming from wall inside .
Old 01-26-2012, 08:47 PM   #4
jproffer's Avatar
Rewards Points: 716
I guess the "flashing" thing is just language barrier ....
at any rate, the only thing I would guess is the ductwork is flexing. It should be "cross bent" to prevent this, but it may not be.
Other than that, I don't know what could be causing it.
Old 01-26-2012, 08:51 PM   #5
Rewards Points: 582
see if the noise is happening when the furnace is turning on or off..ben
Old 01-27-2012, 06:58 AM   #6
Lightfoot's Avatar
Rewards Points: 272
toilet flapper leaking causing the toilet to run every so often? just a guess because i have no idea what flashing means
Lightfoot is offline   Reply With Quote
Old 01-27-2012, 06:22 PM   #7
Bang noise
yes - it should be "Flush"- it is not related with furnace on/off or any faucet on/off . Today I signed up with Direct Energy plubming plan , I will call them tomorrow.
This is definitely something inside the pipe. Any one have idea how air creat problem inside the pipe - I mean make noise . thanks
Old 01-27-2012, 08:18 PM   #8
jproffer's Avatar
Rewards Points: 716
The air and water would have to move to make noise....
If you're sure it's the water pipes that are making noise, something is drawing water.
Old 01-27-2012, 09:24 PM   #9
Rewards Points: 14,312
Check for a flapper leaking in the toilet tank. Just pore in some red food coloring in the tank and see if it leaks into the bowl.
The word flashing still makes 0 since if it's a sound your trying to describe.
Is this a sinlge family home or an apartment or condo?
Old 01-27-2012, 09:40 PM   #10
jproffer's Avatar
Rewards Points: 716
I'm not sure, but I think this was a correction for the "flash" term he was using.
