I Can't Turn Off The Hot Water Coming From My Kitchen Sink! - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2011, 08:35 PM   #1
Question
I can't turn off the hot water coming from my kitchen sink!
Was just about to start dinner, after filling up a pot of water, I turned the faucet and the water wont shut off! I turned the shut off valve under the sink for the hot water so it is temporarily stopped, but I have to finish dinner and need to fix this. Any clues why this happened and what I can do to fix this? I'm somewhat handy, but not sure about plumbing. Any help is much appreciated.
miss_yvonne is offline   Reply With Quote
Old 08-10-2011, 11:09 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is the handle stuck or does it move from on to off position freely?
What kind of faucet is it?
Journeyman Plumber
Old 08-10-2011, 11:16 PM   #3
The handle is not stuck and it does move freely
the faucet is a Price Pfister. and the handle is not stuck and does move around freely
Old 08-10-2011, 11:20 PM   #4
Doing it myself
Alan's Avatar
Sounds like something inside that seats when you turn the valve off came loose, or broke off . . . .
Without being there to look at the faucet, i'd have a hard time telling you how to take it apart. Do you know what the model number of the faucet is?
Usually you take off the handle first and it will reveal something else below that unscrews. Be sure you turn off the cold valve under the sink too if you try to tackle this yourself.
Journeyman Plumber
Old 08-11-2011, 07:40 AM   #5
Rewards Points: 1,548
YOu might get it to temporarily shut off by twisting it at the same time as pushing it back and forth or to the side. Normally a cam inside limits the twist but that may wear out and the handle gets more sloppy and floppy as well as not shutting off the water consistently.
Old 08-12-2011, 02:00 PM   #6
Allan J and Alan, thanks so much for your replies. Turns out the cartridge inside of the handle just needed to be replaced. Didn't even need to take the whole sink apart. A friend showed me how to replace this.
Sump pit keeps filling, can't see water coming in ks-man Plumbing 30 12-31-2014 05:32 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
