I Can't Pay That! Need Plumbing Advice - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2013, 07:29 PM   #1
Rewards Points: 62
I can't pay that! Need plumbing advice
I have to replace the main sewer line from my house, it is about 50 feet or so to the road. I have a big oak tree that is close to the line and the plumbing his old so do the math on that one. I have a deep hole out there that has a sewer leak and need to get this fixed. I got a quote for 1400 and when I told the guy no thanks I will rent equipment and dig the hole myself if possible he then said " well rent the equipment and I will do it for $700".
I would like to know if I can have the utility companies mark where any lines are and I would dig this by hand or have someone with equipment do it if not too much. I would then hire a plumber to do what needs to be done on the pipe. I am on a budget so if i can do the bulk of the work to save some cash I will, I don't mind the hard work.
mclld is offline   Reply With Quote
Old 04-30-2013, 07:41 PM   #2
Rewards Points: 258
most states have a toll free number for CALL BEFORE YOU DIG here is 811 don't know about your area, google your state and CALL BEFORE YOU DIG or ONE CALL
redman88 is offline   Reply With Quote
Old 04-30-2013, 07:48 PM   #3
funfool's Avatar
Rewards Points: 534
First thing I would do, try and find out how deep the sewer is in your particular neighborhood.
I know a guy that did this himself, His house probably sat about 5 feet above the street level, and for whatever reason, the main sewer line in the street was 17' deep.
It was a real challenge for the 4x4 backhoe he had rented.
You can dig it out, start at the house where it comes out under the foundation, find it and keep following it. You can do most of the work, maybe even pull a permit as a home owner and do everything on your end.
I am pretty sure the city will not allow you to do the reconnection to their line. They will be there and do the connection themselves. Then have it inspected and fill it back in.
If you find the average sewer line in that area is about 6' deep or so, sure go for it ... if you find it is 20' deep ... I might chicken out digging it by hand.
funfool is offline   Reply With Quote
Old 04-30-2013, 07:53 PM   #4
jproffer's Avatar
Rewards Points: 716
I would DEFINITELY chicken out digging it by hand...no way. I'm not willing to die over any amount of money.
jproffer is offline   Reply With Quote
Old 04-30-2013, 08:47 PM   #5
Rewards Points: 582
what about diggers insurance....if you dig something up..you are responable...ben sr...1400.00 is pretty cheap...
Old 04-30-2013, 09:28 PM   #6
I wouldn't even know how wide to make the hole for the plumbers. Wear a hard hat.
Dorado is offline   Reply With Quote
Old 04-30-2013, 09:44 PM   #7
funfool's Avatar
Rewards Points: 534
should always call in and mark before you dig. With a shovel and being careful will survive, but better to know where everything is located first.
But Honestly, if you have more time then money, digging out the sewer line by hand is perfectly acceptable. It is good exercise and gives you something to do.
Old 04-30-2013, 10:08 PM   #8
Remember this story from a couple of weeks ago. "Neighbors told WBTV the children are cousins, and that a man is in the process of building a house and was digging out the basement when a wall of dirt collapsed around the two youngsters."
Old 04-30-2013, 10:23 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 996
1400.00????? for 50 ft of line,, my concern would be why so cheap,,
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 04-30-2013, 10:44 PM   #10
Rewards Points: 258
http://www.call811.com/state-specific.aspx
Old 04-30-2013, 11:29 PM   #11
r0ckstarr's Avatar
Rewards Points: 2,064
I did the online submission one day. The very next day when I got home from work, all lines were marked.
r0ckstarr is offline   Reply With Quote
Old 05-01-2013, 06:33 AM   #12
Rewards Points: 3,130
I doubt you would save any money by renting the machinery and having a plumber do the rest. Around here, the delivery/pickup charge, insurance, and a couple of days' rental of a mini excavator would be more than $700. Not to mention the cost of diesel fuel. And while such machines aren't difficult to operate once you get the hang of it, if you've never done it before, you'll be really slow at first.
There is no way I would dig up that pipe by hand. But, then, I'm 65 years old.
I'm with Javiles - $1400 sounds awfully cheap for what you need done. I had a similar length replaced at one of my houses a few years ago, and it was more than double that amount. But if I were you, I'd find a way to pay the $1400 and get the job done in one day. Remember, you'll have no usable toilets or sinks in your house while this work is going on, and I can pretty much guarantee you couldn't do all the digging by hand that quickly.
Old 05-01-2013, 07:19 AM   #13
Rewards Points: 12
$1400 is a deal! We just paid $1550 for ours to be done and that was after negotiating....
rkingndayton is offline   Reply With Quote
Old 05-01-2013, 09:43 AM   #14
Always learning...
fetzer85's Avatar
Rewards Points: 262
OP, have you ever done any plumbing work before?
fetzer85 is offline   Reply With Quote
Old 05-01-2013, 09:59 AM   #15
ready to roll's Avatar
A trench more then 4 feet deep would require shoring. You would have to rent shoring jacks that are a pain in the butt to work with.
ready to roll is offline   Reply With Quote
Under-slab or In-slab plumbing? CplDevilDog Concrete, Stone & Masonry 1 06-13-2012 06:43 AM
Advice on plumbing two water heaters in series TLockwood Plumbing 7 01-10-2012 09:01 AM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 09:12 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
