I Can Light The Pilot, But....(water Heater) - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-22-2011, 04:56 PM   #1
Unhappy
I can light the pilot, but....(water heater)
it won't stay lit very long. Any help would be oh so appreciated!
Linnea
linnea is offline   Reply With Quote
Old 10-22-2011, 05:04 PM   #2
DIY staff
Rewards Points: 7,174
What are you lighting? Furnace?
It sounds like a thermo coupling--Get the name of the unit and let us know---
If it's the thermo coupling--they are easily replaceable and available at a local store.
Old 10-22-2011, 05:14 PM   #3
Lochinvar hot water heater.
Oops, I'm in the wrong forum, aren't I?
So sorry.
Linnea
Metro Detroit
Old 10-22-2011, 05:17 PM   #4
DIY staff
There are a bunch of heating pros here---please be patient--one will be along in a minute or two--
I'm no dummy --but a pro will give you the best advice.---Mike----
Old 10-22-2011, 05:27 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
Hello there. I'm not too familiar with water heaters and although they are a simple creature compared to furnaces it appears that Lochinvar is known to have continuous troubles. Hope this helps.
http://www.justanswer.com/hvac/3ypq9...9501m5117.html
Doc Holliday is offline   Reply With Quote
Old 10-22-2011, 05:32 PM   #6
DIY staff
Is it an older unit that you light with a match or a sealed unit that must be lite by pushing a chicker button??
Old 10-22-2011, 05:34 PM   #7
Just as with a furnace, the flame has to be "sensed" for the unit to stay lit. My guess would be that there is a problem there.
Good luck.
"A PILOT light should burn for many seconds prior to shutting down if the flam sensor fails to detect flame... a main burner should go off within a second or two of flame failure."
Old 10-22-2011, 05:36 PM   #8
DIY staff
I moved this to plumping and added to your title---(I'm magical)--Mike---
Old 10-22-2011, 05:48 PM   #9
Water Heater Pilot
Thanks for the moving assist Mike.
My hot water heater is the kind where I must light it with a match, or candle lighter which is what i use.
I turn the knob to "pilot", light the pilot and then hold the button down for at least a minute.
Old 10-22-2011, 06:00 PM   #10
DIY staff
O.K.--that's repairable by a normal human (unlike the newer ones)
The thermo coupling is a thin copper tube coming out of the bottom of the control box and going down into the burner--the tip of the unit is just above the pilot burner---and is covered by the flame of the pilot when it is lit--
Go look and tell me if you can identify it.
Old 10-22-2011, 06:38 PM   #11
DIY staff
Hot Water Heaters : How to Install a Thermocouple on a Water Heater - YouTube
Got to go---emergency --someones water heater is gushing----Mike---
Old 10-22-2011, 09:23 PM   #12
Thanks Mike.
Watched the video.
Removed the thermo couple.
Will pick up replacement in the morning.
Hoping that installation will be as easy as removal.
Thank you so much for your help.
Linnea
The Following User Says Thank You to linnea For This Useful Post:
oh'mike (10-23-2011)
Old 12-29-2014, 05:07 PM   #13
Rewards Points: 2
Linnea
I had the same problem. Replaced the thermocouple...cleaned the pilot tube and that didnt help....
As it turned out...the ECO switch was open! All I had to do was reset it!!! It was a pop out cirquit breaker type.
brada48442 is offline   Reply With Quote
Rheem 40gal water heater - Pilot won't stay light...thoughts ? anku HVAC 10 05-26-2013 03:55 AM
Gas water heater - after long use pilot goes out. paulsaindon Plumbing 1 07-14-2011 05:51 PM
Water heater won't light adfuhrer HVAC 1 12-10-2010 03:59 PM
Water heater won't light adfuhrer Plumbing 0 12-10-2010 03:11 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
