I Am Stumped At How To Continue Here (P-trap) - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2010, 06:18 PM   #1
Question
I am stumped at how to continue here (P-trap)
So i bought this vanity at a local home inprovement center.
It is an open concept with a glass shelf. Problem being the main from the wall is located too low so where the p-trap sits it is too low and I cant get the shelf in now. I live in a highrise so I cannot open the wall and raise the drain.
I reside in Canada so an s-trap is illegal.
I inquired to get the shelf cut but as it is tempered it would just blow up if they tried. I have attached a couple pictures. I need to gain like 2" here. I dont know if there is a way around this or not.. any suggestions would be helpful.
Chris
Edit. i just put a piece of scrap there to show what height I need to attain.
I am stumped at how to continue here (P-trap)-img-20101123-00001.jpg   I am stumped at how to continue here (P-trap)-img-20101123-00002.jpg
CommandoChris is offline   Reply With Quote
Old 11-23-2010, 08:10 PM   #2
need fittings, if you can tip the drain up with a pair of 22 1/2 degree ells would be best as it will not ruin the venting (siphon the drain).
Ltnicks is offline   Reply With Quote
Old 11-23-2010, 11:22 PM   #3
i'm not a big fan of them, but you should see if you can find a bottle trap that would fit. plus, they're designed for exposed applications (supposedly they look better )
the_man is offline   Reply With Quote
Old 11-24-2010, 07:53 AM   #4
I'm with the_man on this one. Even if you use 22's your still making a s trap. The reason I say that is most code figures your pipe will be 1/2 to 3/4 full of water which gives you in this case 5/8" vent (1 1/4 pipe divided by 2) that means he can only rise 5/8" from the start of the drain to the ptrap. He has to go up way more than that.
immeraufdemhund is offline   Reply With Quote
Old 11-24-2010, 08:00 AM   #5
Plumb or Die!
What's the height of the drain off the floor?
plumber666 is offline   Reply With Quote
Old 11-24-2010, 08:25 AM   #6
Licensed Master Plumber
Looks like you have about 2 1/2 inches from the bottom of the trap to the shelf so niehter a bottle trap or a drum trap is going to work. Using 2 45's turns it into an S trap which is illegal and you can't raise the outlet either so... Try a glass company and see if they can cut you 2 now pieces of glass or if they have a diamond saw they can even cut a circle out where the trap hits. Other than that, take the whole mess back and find something with either no shelf or wood.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 11-24-2010, 10:51 AM   #7
Rewards Points: 1,646
Can you shorten the tailpiece? Hard to tell how much is available from the pictures posted.
bob22 is offline   Reply With Quote
Old 11-24-2010, 02:43 PM   #8
That looks like a rather large drop from strainer to trap, although I can't really see the bottom of the sink. Most codes have a max drop of 15" from sink outlet to centerline of trap. If it exceeds this already, maybe doing something slightly illegal isn't so much of a problem?????
Best would be to get a new vanity or something custom cut.
Fredzilla is offline   Reply With Quote
Old 11-25-2010, 02:43 AM   #9
Chris
if you put a 90 at the wall add a pipe to give you the 2 1/2 inchs then add your p trap if not sure contact me frog1973@hotmail.com thanks steve
steve1973 is offline   Reply With Quote
Old 11-25-2010, 08:24 AM   #10
If he puts a 90 at the wall he will need another 90 above that one and that turns the P trap into an S trap and S traps are not legal.
Old 11-26-2010, 06:07 PM   #11
Rewards Points: 150
Cut into the wall and raise the drain, or get rid of the shelf.
braindead is offline   Reply With Quote
Old 11-26-2010, 06:28 PM   #12
Sorry I can't help it, So far so many comments on making either a s-trap or cut into the wall. I believe the answer was stated earlier of either get rid of the shelf, or find someone to cut the shelf.
I hate flaming, and I'm sorry if i trampled over anyone's feelings but it is not polite to not read the entire post before commenting.
Old 11-27-2010, 04:27 PM   #13
I should have mentioned that the vanity did come with a bottle trap that did not fit either. NHmaster i did inquire as to how much a new peice of glass with a notch cut out of it would be and he said around $500.
I really appreciate all the feed back guys. It looks like I will just stain a piece of wood. It'll go with the wood part of the vanity and wont look out of place.
Old 11-28-2010, 05:10 AM   #14
Guys,
If you do a 90 at the wall and a tee on top of the 90. you place the trpa adapter on the outlet of the tee. Place an AAV "studor vent " on top of the tee. You now have a vented s-trap that is totally legal.
Work4living is offline   Reply With Quote
Old 11-30-2010, 02:09 PM   #15
Originally Posted by Work4living View Post
Guys,
I'd say that is the winning idea!
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Keep cast iron trap or new ABS trap? thebigsee Plumbing 1 01-26-2010 03:18 AM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 07:30 PM
