*@$#%! I _________ Up!!!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2012, 08:41 PM   #1
Rewards Points: 155
*@$#%! I _________ up!!!!
Total oversight on my part- Kitchen cabinets are in and grante counters with sink are now installed. In installing the granite counter- they also installed a 9' deep "undermount" sink. When I went to eyeball the garbage disposal install I notice the outlet from the disposal is 2-3" lower than my drain. I cannot lower the drain at all since it comes in from the side wall and making it any lower would throw off the natural pitch out the main. I can buy another sink which is same dimensions but 7.5" deep but I don't think that helps me enough. Do they make any disposals where the outlet is less than 6" down???
I'm beside myself knowing I made this poor error and feel there is no way out.
HELP
Huskyfan68 is offline   Reply With Quote
Old 12-05-2012, 08:47 PM   #2
Rewards Points: 79
How about going with a 6 inch deep self rimming sink?
Our just not using a disposal? Garbage wasn't meant to go down the drain anyway.
eclark is offline   Reply With Quote
The Following User Says Thank You to eclark For This Useful Post:
joecaption (12-05-2012)
Old 12-05-2012, 08:51 PM   #3
HELP
You sure you won't be okay once a p-trap is installed??
renoit is offline   Reply With Quote
Old 12-05-2012, 08:51 PM   #4
Rewards Points: 155
I really can only change the sink with one that will fit in the opening. The counter is already cut to fit the sink
Old 12-05-2012, 09:13 PM   #5
Rewards Points: 155
the P trap is what comes out of the disposal and goes down correct? Won't it still be an issue if the main drain is still higher than disposal outlet?
Old 12-05-2012, 09:33 PM   #6
Rewards Points: 582
take a picture so we can see what you got..ben sr
Old 12-05-2012, 09:44 PM   #7
Rewards Points: 155
you can see the outlet from disposal (no P trap) and waste drain off to the right
http://s686.beta.photobucket.com/use...43625335474734
Old 12-06-2012, 12:00 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 564
You can get a closer coupled disposal- perhaps a Badger. But it still looks a little close.
Also look at sinks with a shallow bowl on one side
Old 12-06-2012, 02:44 AM   #9
DIY staff
Rewards Points: 7,174
Garbage disposers are not necessary---you could learn to live without it---
COLDIRON (12-06-2012)
Old 12-06-2012, 07:54 AM   #10
Rewards Points: 3,130
I did something similar when I remodeled a kitchen a few years back. I can tell you with certainty that the drain MUST be below the disposal's outlet. If you can't figure a way for that to happen, don't install the disposal.
Old 12-06-2012, 07:59 AM   #11
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
2 suggestions:
Get a GD with a shorter neck. The 1 in your picture is not typical.
I do not see why you can not open the wall and lower the trap arm tee. PIA but doable.
Coastal South Carolina
Old 12-06-2012, 08:23 AM   #12
Rewards Points: 155
if anyone knows of any GD's that have higher outputs let me know- most of the one's I've looked at look about the same- thanks
Old 12-06-2012, 08:32 AM   #13
Rewards Points: 582
wall is not in very good shap anyway...cut board out lower drain line.....1/2 hr tops....ben sr
Old 12-06-2012, 08:37 AM   #14
Rewards Points: 155
thanks all- I cannot lower drain line- thats part of the issue- the drain comes in from the basement (split level house)- The kitchen is on a slab- The drain goes out the back (which is actually the basement ceiling)- then pitches all the way to the right (about 20') to the main drain outlet- It's as low as it can go
Old 12-06-2012, 08:57 AM   #15
A "Handy Husband"
rjniles's Avatar
Insinkerator GD's have the drain hole 6"(measure to center of hole) below the bottom of the sink, yours looks a lot more that that .
