Hydronic Zones Get Some Heat When Not Called - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-21-2010, 04:40 PM   #1
hydronic zones get some heat when not called
I have a hydronic heating system with six zones operated by six pumps. I have noticed that when one (any) zone calls for heat there is a small flow to all the zones. This is particularly a problem when I try try to heat up my garage shop because it takes several hours to bring up the heat up about 20 degrees and in the meantime the rest of the house gets hot. I can only assume that some of the hot mix seeps through the other wet rotors that are not active. I am wondering if there is some way to prevent this from happening?
1619Farm is offline   Reply With Quote
Old 12-21-2010, 06:46 PM   #2
Licensed Master Plumber
Should be flow check valves installed on the outlets, are there?
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 12-21-2010, 06:48 PM   #3
Rewards Points: 1,418
Yes there is some small flow through the zones that azre not calling for heat.
In most systems this does not cause any inconvenience.
To stop this seepage you need to install (electrically powered) valves that physically shut off the zones not calling for heat.
Old 12-21-2010, 08:17 PM   #4
No. I will have my plumber install them. Thanks!
Old 12-21-2010, 08:24 PM   #5
Is there some advantage to installing relay controlled valves, or are mechanical check valves enough? Right now I have no check, and some parts of the house get up to 5 degrees above my thermostat set points when the furnace is working to heat somewhere else.
Old 12-21-2010, 09:31 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,... I've had good luck with spring check valves for stopping ghost flows,...
The system I just put in my rental has the check valves built right into the circulator pumps...
Bondo is online now   Reply With Quote
Old 12-22-2010, 09:31 AM   #7
My Grundfos pumps do not have check valves. I will be installing Taco Flo-check valves soon. Thanks to all who helped.
Old 12-22-2010, 10:28 AM   #8
Bondo's Avatar
Rewards Points: 354
Ayuh,... Mine are new Grundfos,...
Maybe it might be worth checking to see if the check valves can be retrofit to your pumps....
The valve just pops into the pump's outlet...
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Hydronic Radiant Floor Heat KGP HVAC 22 05-02-2011 09:31 AM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 03:21 PM
Heat source for hydronic radiant floor heating mattedfred HVAC 1 11-19-2008 06:58 PM
