HWT Recirculation Loop Retrofit - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-15-2011, 10:57 AM   #1
HWT recirculation loop retrofit
Hello,
I want to add a HWT forced recirc loop to my existing home. I want to do it with a dedicated return line to the HWT, so as not to pollute my cold water with water from the hot line.
I am capable of doing the mechanical aspect of the job, but want to confirm the system design and required parts
so I'll need a pump, an aquastat (I want the pump to run when the water at a certain point in the loop gets to a predetermined temp)
I believe I'll need a anti-flowback valve on my cold water supply, also. or is this typically built into HWT's? Will I need an expansion tank on my cold side also?
any advice on this would be greatly appreciated!
thanks
chris_s is offline   Reply With Quote
How do you use a loop roller? redline Painting 8 04-02-2013 10:05 AM
Recirculation Line Naveen Plumbing 6 08-07-2011 04:21 PM
Kitchen Drain Pipe Loop tpsilk Plumbing 4 07-02-2011 08:56 AM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 01:08 PM
To Switch loop or not to switch loop beezlebub03 Electrical 7 06-17-2008 07:04 PM
