HVAC Humidifier Drain Freeze - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2013, 09:51 AM   #1
I have a inline humidifier for my upstairs HVAC unit that drains with the AC. This pipe runs down the outside wall of the house from the attic in a 1/2 inch PVC pipe. The ac drains in the same pipe durring summertime use. The pipe is insulated with foam and has a freeze wrap that plugs into the wall and wraps the full lenght of the pipe with really close wraps near the bottom. It still freezes durring cold temps and backs water up into the attic and thus floods the upstairs. I have pucks that shut down the system and cut the water off when it detects water in the pan. This has limited the flood issue but its still a pain to have to baby sit this system all winter long.... Here is my question: Can I run the drain (which handles very little water volume) into a vent stack from my 2cnd floor bathroom instead of outside of the house to prevent flooding?
jonathanh2o is offline   Reply With Quote
Tags
humidifer problem , hvac attic heatpump , plumbing
"custom" washer drain using rain downspout- venting question denemante Plumbing 5 02-13-2013 07:56 AM
Zep Drain Care for larger drains? Ultrarunner2017 Plumbing 13 01-10-2013 09:51 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
