Huuhhu - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2012, 07:47 AM   #1
Huuhhu
Thx.... I'm looking to run water pipes through exterior walls. Is this a no no or is there a solution?
Kipster is offline   Reply With Quote
Old 04-30-2012, 07:48 AM   #2
I'm looking to install water pipes in an outside wall. Is this a complete no no iot is there a solution?
Old 04-30-2012, 07:59 AM   #3
the Musigician
DangerMouse's Avatar
I have water pipes along the floor in a soffit that allows heat flow through it, but it's on the inside of the exterior wall, not IN the wall.
DM
Old 04-30-2012, 08:01 AM   #4
Ironlight's Avatar
It all depends on where you live and some other factors. Your local building codes may have something to say about it as well.
As an example, I live in Washington DC and I have my kitchen sink supply lines running for @ 20' around the northwest corner of the house. They run inside the insulation and I don't have a problem with freezing. Were I in Wisconsin I can bet that arrangement would be completely unacceptable.
Ironlight is offline   Reply With Quote
Old 04-30-2012, 09:50 AM   #5
Rewards Points: 1,442
Little known fact: In freezing climates it is better for the pipes if there is no insulation between them and the wall surface on the inside (heated side).
