Humming In Pipes? But No Water Leaks We Can See. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-25-2010, 03:39 PM   #1
The Big Builder
Humming in Pipes? But no water leaks we can see.
Hello,
I am a general handyman that was helping out an older couple fix some small items around their house. Leakign toilet, sink strainer, flood light, and landscaping.
They said they had a humming in the house and that they couldn't figure out the cause. They said it sounded like it was in the pipes.
My experience with these hums is due to toilets when they are getting close to being filled or something leaking. I looked all over the house and it didn't look like anything was leaking. The sound sounds like it is coming from upstairs, doesn't seem to be related to flushing the toilet or running the faucets. They can just be sitting there and all of a sudden hmmmm.
They said it has been like that for 5 years now and they are really tired of it.
Any ideas?
Stephen
bigbavarian is offline   Reply With Quote
Old 06-25-2010, 05:38 PM   #2
not enough vent in the vent stack or no vent at all
Bldg 2 Spec is offline   Reply With Quote
Old 06-25-2010, 11:45 PM   #3
Do something
D'Brie's Avatar
Check the water pressure, it should be 80 psi or lower.
D'Brie is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Hot water pipes (closed system) vibrate very loudly. Peety HVAC 8 02-07-2010 10:53 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
