Humming Noise When Water Runs - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2012, 07:15 AM   #1
kdo
Humming noise when water runs
Our pipes hum when we run the water. Mostly when the water is running full blast. It stops when we stop running the water. What could be causing the problem?
kdo is offline   Reply With Quote
Old 08-02-2012, 10:26 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I vote either a fill valve on a toilet or a leaking hose bibb/atmospheric vacuum breaker.
Turn the water on, and go to those sources and see if you can identify one of them as the noisemaker.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oh'mike (08-02-2012)
Old 08-02-2012, 10:26 AM   #3
Rewards Points: 12,886
Pipe rubbing aginst a joist, loose washer in a faucet, water pressure set to high, dirty aerator in the faucet, just a few suggestions.
Old 08-02-2012, 11:03 AM   #4
when we moved to ohio 2 years we kept hearing a noise everytime the water would run. turned out it was the water meter inthe basement. a call to the water company and they came out and installed a quiet meter. check the main valve and make sure its open all the way. could be a globe valve with a loose washer.
Old 08-02-2012, 07:11 PM   #5
Rewards Points: 582
see if you have a pressure regulator at the water meter... they can make a humming noise...
Eternal Hybrid Water Heater Noise jacquesstrap Plumbing 7 02-03-2012 03:31 PM
how to fix water hammering noise newhomenj Plumbing 9 01-08-2012 11:49 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
