#1 |
Huming sound after water is ran
When we flush the toilet or run water in our home there is a humming/vibrating sound after the toilet tank fills and that water shuts off. It started a few weeks ago and progressively gotten worse. Any ideas as to what the problem may be? I am trying to avoid the need to call a plumber if necessary. Below is a link to a video i posted where I flush the toilet and you can hear the sound. Thanks for any help or suggestions in advance.
http://www.youtube.com/watch?v=4LWvUNsg7Ao |
#2 |
Super Moderator
That's a weird one--
Most time a vibration/groan like that is caused by a valve the is not closing completely---chattering as it finally shuts off. Try turning off the shut off under the toilet---if that cures the noise you will know the the toilet guts are the problem. Also --when the toilet tank is full--push down the float lightly---see if the groaning happens just as the valve is trying to shut off.
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
you could have a problem with pressure reducing valve ...if you have one... I would follow mike's advice .. if no reducing valve
| Tags |
humming, pipes, plumbing, toilet ![]() |
| Display Modes | |
| No hot water at any faucet, water heater working fine | rivercliff | Plumbing | 5 | 10-27-2011 10:47 AM |
| No water draining into sump pit | aci4369 | Plumbing | 2 | 08-18-2009 01:17 PM |
| How Do I Properly Shock Chlorinate a Water Softner | classicflytyer | Plumbing | 5 | 07-14-2009 01:15 AM |
| the sound of water.... | mmhendrie | Plumbing | 5 | 04-25-2009 08:23 PM |
