Hubless Coupling Vs. Fernco - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-18-2008, 12:36 PM   #1
Joe F's Avatar
Rewards Points: 294
Hubless coupling vs. Fernco
I just had my MBR toilet moved about 3'. The plumber removed a section of the 3" cast and replaced it with PVC and used a Fernco to connect the new PVC to the old cast. Is a Fernco OK for this application or does it need a hubless coupling?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 09-18-2008, 12:51 PM   #2
Registered User
Termite's Avatar
Fernco's are often used to transition from cast to PVC. As long as he used the correct size and configuration, it shouldn't be a problem at all.
Old 09-18-2008, 01:07 PM   #3
Joe F's Avatar
Rewards Points: 294
Thank you.
Old 09-20-2008, 10:56 AM   #4
Fernco is fine as long as it is above ground.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
no-hub terminology davefoc Plumbing 16 03-16-2009 06:15 PM
How do you remove plastic coupling nut and washer from braided metal connector? tony__s Plumbing 3 05-15-2008 11:15 PM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 06:39 PM
cast-iron to PVC banded coupling amakarevic Plumbing 1 07-14-2007 03:02 AM
fernco coupling farrington135 Plumbing 2 03-09-2007 10:12 AM
