-   -   Hubless coupling vs. Fernco (http://www.diychatroom.com/f7/hubless-coupling-vs-fernco-27003/)
Joe F 09-18-2008 11:36 AM
I just had my MBR toilet moved about 3'. The plumber removed a section of the 3" cast and replaced it with PVC and used a Fernco to connect the new PVC to the old cast. Is a Fernco OK for this application or does it need a hubless coupling?
Termite 09-18-2008 11:51 AM
Fernco's are often used to transition from cast to PVC. As long as he used the correct size and configuration, it shouldn't be a problem at all.
Joe F 09-18-2008 12:07 PM
Thank you.
majakdragon 09-20-2008 09:56 AM
Fernco is fine as long as it is above ground.
