Hroom Rough In - What Type Of Shower/Tub​? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2012, 11:54 AM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 806
Originally Posted by Beepster View Post
If the vanity vent is also the toilet vent, that would make it a "wet" vent. I was always a little fuzzy on the dos and don'ts of wet venting. Does that vary between jurisdictions?
B
Yes, as do several other aspects of plumbing. That's why it's important to check with the locals- just a couple phone calls can clear the air.
Old 01-27-2012, 12:00 PM   #17
Plumber
Rewards Points: 806
Originally Posted by j_killmeyer View Post
That's a really good idea about the 36 X 48 shower. At least now I have a couple of ideas/options. As for getting the vents up through the ceiling - I have no idea. How is that usually done? I have a two story house with living space above this area. Can you vent out the side wall or does it have to be through the roof?
Look around the basement ceiling for a capped 2" pipe, If the plumbers were thoughtful, they dropped a vent down for you. Side wall venting is frowned on in my area, but you could possibly use "studor" vents.
Do you know what plumbing code is used in your area? Some inspectors don't like AAV's (studor)
The Following User Says Thank You to TheEplumber For This Useful Post:
j_killmeyer (01-27-2012)
Old 01-27-2012, 12:47 PM   #18
Thanks - I'll take a look when I get home and cross my fingers that they did! This has been very helpful - thanks so much!
j_killmeyer is offline   Reply With Quote
Old 01-27-2012, 01:39 PM   #19
Plumber
Rewards Points: 806
You're welcome. I'm sure you'll get more responses as the day goes by. Seems like all the other plumbers had to work today
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
rough edges with much missing gravel on Timbertex cdelfeld Roofing/Siding 12 12-04-2011 08:12 PM
Bathroom layout to fit rough in? bryanl Remodeling 6 09-21-2011 08:02 AM
Type L or M copper BlueBSH Plumbing 12 11-22-2010 08:54 AM
