Howling Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2008, 09:31 AM   #1
Unhappy
howling pipes
I renovated a bathroom, installed a new sink and ever since i cannot turn on the water to the sink due to excessive howling and vibrating pipes. it sounds very bad. the toilet runs fine, jacuzzi fine. help!
joani329 is offline   Reply With Quote
Old 11-09-2008, 11:10 AM   #2
If this happens with both the hot and cold, start with the easiest inspection. Remove the aerator on the end of the spout and then turn on the water. The aerator will block anything in the lines from exiting and can cause noises. If that is not it, then you need to check either the washers on the end of the faucet stems (if a two handle faucet) or the cartridge if it is a single handle. You never know what may have been left in the faucet from the factory or how long it was stored. This could cause drying out of "O" rings and washers.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-11-2008, 07:01 AM   #3
thanx!
thank you for your response. I am goning to try this today.
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Replacing pipes in bathroom, need advice Steelmesh Plumbing 7 11-04-2008 11:30 AM
fittings and pipes sizes.. effect on pressure? cgerikh Plumbing 3 05-19-2008 10:37 AM
frozen pipes helper Plumbing 3 03-23-2008 12:35 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 12:06 PM
