How Would You Support Pipe In Existing Joist Space? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2011, 09:03 AM   #1
Rewards Points: 129
How would you support pipe in existing joist space?
I'm building out a brand new bathroom. Running the plumbing parallel to the joist space. So I've cut up some floor and know I need to support the pipe every 48 inches. Just wondering how. 2x4 blocking? steel wire? straps? What can I attach the supports to? This needs to pass inspection.
wease is offline   Reply With Quote
Old 02-05-2011, 09:14 AM   #2
I use band iron or hanging strap. Thin metal strapping with holes every 1/2 inch. You can go from one joist to another to make like a saddle to hold the pipe up.
broox is offline   Reply With Quote
Old 02-05-2011, 09:18 AM   #3
Rewards Points: 129
Is that code ok? I wonder about the metal strap cutting away at the pipe? Do you need to attach the pipe to the strap or can it just rest on there?
Thanks.
Old 02-05-2011, 09:27 AM   #4
it can just rest there
Old 02-05-2011, 09:46 AM   #5
Rewards Points: 129
Thanks. You wouldn't happen to know how a tub/shower combo drain should attache to the joists. Do I need some kind of solid attachment method?
Old 02-05-2011, 10:03 AM   #6
the tub and shower drain attaches pretty solidly to the tub and shower, so I do not worry about putting a hanger on the p-trap, I just put one close on the pipe leaving the trap.
Old 02-05-2011, 10:28 AM   #7
are you talking about drainage pipe or water pipe? you can hang abs/pvc with p tape (2 hole strap) but you don't want to do it with pex or copper tubing. for water lines you want to get the appropriate pre made hanger
the_man is offline   Reply With Quote
Old 02-05-2011, 01:04 PM   #8
Homerepairguy's Avatar
Rewards Points: 990
+1
Definitely use appropriate hanger for pex or copper water lines. Either can deteriorate if hanger/supports are made out of an incompatible material.
Homerepairguy is offline   Reply With Quote
Old 02-05-2011, 03:31 PM   #9
Rewards Points: 129
ABS 3" pipe. What's p tape?
Old 02-05-2011, 05:18 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 350
any box store should have it
Old 02-05-2011, 08:00 PM   #11
I asked at Mailboxes etc. and they did not have any
I am sorry, I just could not help myself.
Old 02-05-2011, 08:16 PM   #12
Plumber
Rewards Points: 350
You should have picked up some strapping tape though. It's good stuff
Old 02-06-2011, 03:49 AM   #13
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
if youre hanging plastic pipe use the plastic plumbers strap,metal will cut into plastic pipe.
plummen is offline   Reply With Quote
Old 02-06-2011, 09:24 AM   #14
Rewards Points: 129
That's exactly what I mentioned above. Do they sell plastic at the box stores?
Old 02-06-2011, 09:38 AM   #15
Rewards Points: 1,418
A saddle should be V shaped. A straight (horizontal) saddle is more apt to spoil the down pitch of the drain pipe if it loosens and sags. And it takes less vibration to loosen up a straight saddle compared with a V saddle.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Pipe Floor Support smata67 Plumbing 0 05-26-2010 08:54 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 03:18 PM
Tying in floor joist to existing structure hebrewdiver Building & Construction 4 05-01-2009 08:44 PM
