Old 08-25-2012, 03:28 PM   #1
Question
How would I move this?
What kind of bit would I use to cut a whole in my foundation?
i would be moving it to within and inch or two of the other foundation wall. Does that work.
altja is offline   Reply With Quote
Old 08-25-2012, 04:25 PM   #2
Why does it need to be moved? A whole lot more involved then just making a new hole.
Old 08-25-2012, 04:58 PM   #3
I am trying to make a bar and various pieces of furniture work. The 4 inches extra this sticks out causes problems with the room configuration. I am trying to way this option verse others that i feel have more draw backs. What else would I need to consider when cutting a hole?
Old 08-25-2012, 05:08 PM   #4
call me E
TheEplumber's Avatar
making a hole is easy- contract a core drilling company to drill a 5 or 6" hole.
Moving the pipe may be a little tougher.
The Following User Says Thank You to TheEplumber For This Useful Post:
altja (08-25-2012)
Old 08-25-2012, 11:16 PM   #5
That looks like a drain to a septic tank that's going to be running under ground on the other side of that wall.
The cap is a clean out.
I sure would be figuring out a way to build around it, that clean out has to stay accessible.
Old 08-26-2012, 12:29 AM   #6
you are adding 270 degrees of turns minimum to reroute it.
i would revise my plans. have a plumber come out and give you a price.
How hard is it to move southernmom Plumbing 8 11-12-2010 11:07 PM
MTD snowblower wont move? caveman79 Landscaping & Lawn Care 7 04-05-2010 10:33 AM
to move or not to move...the panel DangerMouse Electrical 7 02-24-2009 06:34 AM
