How To Turn Down My Hot Water Heater? [picture Attached] - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-04-2009, 07:45 AM   #1
DIYguy2000's Avatar
Rewards Points: 93
How to turn down my hot water heater? [solved!]
Hi,
We just recently purchased a house, and the Rheem Ruud Power Vent PVW50 gas water heater temperature is set way too high. There is no 'obvious' knob on how to turn down the temperature. There are two hex screws, but I don't really feel like playing around if I don't know what to do. Comments are appreciated!
Thanks,
Dave
How to turn down my hot water heater? [picture attached]-dsc03672_sm.jpg   How to turn down my hot water heater? [picture attached]-dsc03671_sm.jpg   How to turn down my hot water heater? [picture attached]-dsc03670_sm.jpg
DIYguy2000 is offline   Reply With Quote
Old 11-04-2009, 11:50 AM   #2
Power vent
Have you tried looking under the grey cover in the upper right?
I don't know for sure but it should have a thermostat of some kind and that might be what the 2 wires are. I wouldn't adjust the allen screw; those are probably gas pressure flow control/regulators.
geoffrey hall is offline   Reply With Quote
Old 11-04-2009, 01:43 PM   #3
DIYguy2000's Avatar
Rewards Points: 93
I don't believe I can remove the grey box at the top right - I think its permanent. I'm not at home right now, but I'll check when I do get home.
There are also a few components at the top of the water heater (vent, blower, etc.) could it be up there? Again, I don't see anything obvious up there.
The heater was installed in '97, so it's not too old.
The user manual didn't come with it when we bought the house. Can I find it online? or should I just call the manufacturer to ask how to adjust it?
- Dave
Old 11-04-2009, 06:19 PM   #4
The water heaters that I've installed have been non=powered. Gravity vent or electric is my thing. I don't think your situation is that complicated; you just need to hook up with a pro-plumber. You might try to post your problem again. You SHOULD get multiple, satisfactory replies, I would think. Sorry.
Old 11-04-2009, 07:16 PM   #5
Rewards Points: 1,520
Why not call Rheem:
Phone: 1-800-432-8373
Fax: 334-260-1341
Available between 7AM - 7PM Central Standard Time (CST)
Weekdays
bob22 is offline   Reply With Quote
Old 11-04-2009, 09:52 PM   #6
Registered User
Rewards Points: 4,894
If you absolutely can't wait, try one of these: http://www.rheem.com.au/manuals.asp?view=domestic They may be similar.....
Be safe, Gary
Old 11-05-2009, 08:05 AM   #7
DIYguy2000's Avatar
Rewards Points: 93
Thanks everyone for your replies. As was suggested earlier, I looked at that grey box at the top right in the pictures. I originally thought it was fixed in place, but it was removable by squeezing the sides in (compression fit). I found the small thermostat dial under a layer of insulation. It was set between low and med, which resulted in scalding hot water. I'd hate to see what 'high' would do! yikes. Turned it down to low last night. Perfect temperature this morning.
Thanks everyone!
Dave
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
water pooling ontop of water heater nannerkrns Plumbing 2 09-23-2008 11:04 PM
