How To Tune An Electric Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2013, 06:02 PM   #1
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
How to Tune an Electric Water Heater
I have an 80 gallon electric water heater, and I just installed a new shower fixture. The single handle Delta shower will only put out 100 water. The tank is set on 150. The shower head that came with the set is a 2 gpm head, it runs out of warm water in exactly 15 minutes. I bought a 1.5 gpm head and it will last 20 minutes. How do I check our water heater to see if an element is shot or a thermostat, could it be the filler tube ate up, any suggestions?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-28-2013, 07:54 PM   #2
The symptoms you describe are frequently caused by a burned out lower heater element. Heater elements are tested by electrically isolating them (disconnecting from electrical circuit completely) and checking resistance of the heater element. A failed unit will have very high resistance.
Bob999 is offline   Reply With Quote
Old 01-28-2013, 08:01 PM   #3
Rewards Points: 13,458
http://www.water-heater-repair-guide...nttesting.html
Old 01-28-2013, 08:02 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Thanks Bob, I will check the element.
Jim
Old 01-28-2013, 08:40 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 564
Did you set the hi temp/anti scald setting at the valve? Seems a little odd your heater will have issues when you replace a shower valve
Old 01-28-2013, 09:03 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Yep, and those delta anti scald are a little funky if you aren't familiar with them.
I personally don't like them.
Journeyman Plumber
Old 01-28-2013, 09:06 PM   #7
Roofmaster
Rewards Points: 2,172
Check the temperature of your water at a simple dual handle fixture. I bet you have the anti-scald feature in the fixture set wrong. By the way 150 degrees is too high if you have kids.
Old 01-28-2013, 09:15 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
The problem didn't start with the new valve we had to turn the water down to a very low trickle to get a shower before. But now with the one handle set up it is much worse because we can't turn the water down to a trickle. I did set the fixture to wide open hot a little while ago and the water hits 139 which we turned down so it would only hit 110. Even with the temps turned down the warm water wouldn't last but 20 minutes before it started getting cold.
I was reading online where after a few years the heater will fill up with trash and not work well, have any of you ever heard of that?
Jim
Old 01-28-2013, 09:34 PM   #9
Doing it myself
Alan's Avatar
Either way, they're both easy to check.
Turn off the power to the water heater. Disconnect both wires from the elements.
Measure resistance on both thermostats, report back with readings.
Usually somewhere between 12 ohms and 14 ohms is a good reading.
Journeyman Plumber
Old 01-28-2013, 10:52 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Thanks Allan, I appreciate your help.
Jim
Old 01-29-2013, 07:51 AM   #11
Roofmaster
So what did you find out?
Yes they can fill with sediment, then the thermostat doesen't work right.
Old 01-29-2013, 08:17 AM   #12
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
I haven't had a chance to get out there yet, I will post what I find as soon as I can check it out. I got a feeling that is what it is, several years back I looked at a friends water heater near here and it had all kinds of clear gel looking stuff in theirs, I just replaced it for them. Thanks for helping.
Jim
Old 01-29-2013, 10:24 PM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
I still haven't had a chance to check the water heater, I have been too busy getting a shower to work for us. I think I have a solution to be able to adjust the water back down to make it last longer instead of it running wide open with the new shower. I took the old valve apart and luckily the valve is a Delta, I rebuilt the entire valve for about $20 so now we can adjust the water as we like it and still use the new valve also. Here is a picture of how I plumbed it in to work either way, the sweating isn't pretty but this is mine and not a client's.
How to Tune an Electric Water Heater-plumbing-3.jpg   How to Tune an Electric Water Heater-plumbing-5.jpg
Jim
Old 01-31-2013, 08:58 PM   #14
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
For crying out loud, I can't believe it, we looked outside to see what the weather was doing and Judy heard water rushing and water all over the yard. We went outside and the main water line to our house had busted in the middle of the yard, water was gushing up out of the ground. How in the world did the pipe bust? Surely the new plumbing didn't have anything to do with it, I hope.
It was too dark to dig the yard up tonight so tomorrow I guess we will see what the problem is. I know one of the elements in the water heater works because when I went to shut it off it was sizzling pretty good.
All the nice warm weather we had and no water leak, just let it turn off cold...
Jim
Old 01-31-2013, 09:18 PM   #15
Doing it myself
Alan's Avatar
That sounds like fun
What kind of depth do your waterlines in your area have to go to?
Journeyman Plumber
Adding ground to electric water heater tadc Electrical 8 03-05-2012 08:14 PM
electric water heater shut off caryn keeper Plumbing 8 02-28-2012 06:39 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 10:43 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
