Old 11-30-2012, 07:25 PM   #1
Question
How to tighten faucet nut
Today I had to replace a kitchen faucet.
The faucet is of the single hole design and has a threaded shank that passes through the top of the counter behind the sink. A nut goes on the shank and secures the faucet to the counter when tightened.
The problem is that the wall behind the sink and the sink itself provides very little room to get a tool up there to tighten the nut. I tried a "plumbers" wrench but the thickness of the jaws wouldn't permit a grip on the nut.
Any ideas on how to tighten this bad boy much appreciated.
sybaris is offline   Reply With Quote
Old 11-30-2012, 07:48 PM   #2
By "plumber's wrench", do you mean a basin wrench, like this:
or a pipe wrench, like this:
If the former, that is the correct tool. Maybe someone else will chime in with a suggestions of what works when that doesn't.
jbs11 is offline   Reply With Quote
Old 11-30-2012, 07:49 PM   #3
Is it a brass hex nut or a plastic one with the ears on it.
If it's plastic one of these may work.
http://www.bing.com/images/search?q=...E2CC7&first=46
Sometimes I've had to remove the sink to get to the nut.
Old 11-30-2012, 08:08 PM   #4
Thanks for the responses.
I tried a wrench like the first one. No way I could get a pipe wrench close to it.
The nut is brass, no ears on it. If it had ears on it I could get a pin or flathead on an ear and tap it with a mallet to tighten. I don't even think removing the sink is an option because it is an under counter mount which means I would have to break the seal, remove the garbage disposal and all the other plumbing and also the center support for the doors.
Old 11-30-2012, 08:14 PM   #5
Lay up in there and take a picture. Easyer to figure out how to do it if we can see it.
Old 11-30-2012, 10:23 PM   #6
Doing it myself
Alan's Avatar
Does it look like this one?
http://0.tqn.com/d/plumbing/1/0/i/5/...ten_faucet.jpg
Journeyman Plumber
Old 12-01-2012, 12:32 PM   #7
See attached
thanks
Old 12-01-2012, 01:15 PM   #8
If you could find a " crows foot " that size it may work or you may be able to modify a router collet wrench to fit.
I was hoping the plumbing industry was nearing the end of their rope in the stupidity department but I guess not.
Fairview is offline   Reply With Quote
Old 12-01-2012, 02:43 PM   #9
call me E
TheEplumber's Avatar
If a special wrench didn't come with the faucet, then it's "necessity is the mother of invention"
Old 12-01-2012, 02:47 PM   #10
I have had the exact same deal in my kitchen. Single stem, deep sink bowls, little access. I managed to get a basin wrench on it and tighten it, but moving the spout from side to side is loosening it right back up. Poor design I guess, I learned my lesson haha next time I get a 3 hole faucet haha
mterry is online now   Reply With Quote
Old 12-01-2012, 02:53 PM   #11
Judging by that picture there's more then enough room for a bason wrench.
Just may take two hands because the nuts so thin. One to turn the wrench, one to hold up the hook until you start turning it.
Changing faucet - reverse osmosis adapter grand_canyon Plumbing 4 11-20-2012 11:29 PM
How to tighten the big 2" nut under the kitchen faucet? lameon Plumbing 3 06-04-2012 07:40 PM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 09:45 AM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 09:29 AM
Ice in Cover over Exterior Faucet SPetty General Discussion 13 01-11-2010 04:32 PM
