Old 11-06-2009, 05:04 PM   #1
Default how to test my sump pump..
its been about 3 years since my sump pump last ran. I know, that's a good thing, right?.. Anyway i'd like to test it. I tried putting a hose down the hole but its so dry down there that i ran it for like 20 minutes and i can't get the water up to a level where it kicks on.
The drain pipe is PVC so its not like i can just "lift up" the pump to put it into a bucket to create the pressure to turn it on. Are there any tricks to get it to come on since it is difficult to lift the pump?
thanks..
windowguy is offline   Reply With Quote
Old 11-06-2009, 06:53 PM   #2
you could just disconnect it at the check valve or union whatever you have to take the drain pipe apart then test it in a bucket etc.
plumber Jim is offline   Reply With Quote
Old 11-06-2009, 08:10 PM   #3
Civil Engineer
Just lift up the float to see if it comes on. If you only run it for a few seconds it will not hurt the pump, even if the sump is bone dry.
Old 11-07-2009, 12:08 AM   #4
True. That will tell you it the motor works but not the impeller. If the impeller is bad it will run but not pump.
Old 11-08-2009, 07:27 PM   #5
theres no float.. its one of those kind that goes on with the "pressure" of the water..
Old 11-09-2009, 12:31 AM   #6
Can you take off the cover and reach down into the pit (the sump) and stuff any incoming pipes (say from a perimeter drain system) with wads of cloth small enough to fit but large enough not to get lost in those pipes? Then see if you can fill the pit with plain water and see if the pump comes on at a proper time.
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
More On This Topic
Hi this is Howard Fleischmann with Community Tire in Phoenix, Arizona on behalf of Expert Village. In this clip we will be finishing hanging the fuel tank in place and getting the filler hose and the vent hoses back on and clamped. Once the straps are... Read More »
Water gardens can add beauty to any landscape. Once you install your water garden pool, it's time to add a water garden pump. This pump will add visual interest with the movement of the water, as well as circulate water to avoid stagnant water, which... Read More »
Hi I'm Dough. I work with 20 great guys in Saint Lois at Doug Jenkins Custom Hot Rods. We are going to do some work for you today on Expert Village. Now Mark is removing the windage tray, every engine of various designs has plates installed or trays and... Read More »
Hi, my name is Jeff Fiffie. I'll be showing you how to remove and replace a fuel pump on a Lincoln Continental. Now we ready to put our tank back in position. With the right hand, you're going to need to guide the tank up and in, in a proper position and... Read More »
Hi, my name's Jeff Fiffie. I'll be showing you how to remove and replace a fuel pump on a Lincoln Continental. Okay we want to make sure our hose is nice and firm. Okay now for our return hose, we'll slip it into place. Okay now grab our bigger return... Read More »
Sump pump pit water level --- problem de12 Plumbing 24 11-04-2009 11:52 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 09:50 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 10:37 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 08:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 06:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
