How To Test For Leaks. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2013, 09:39 PM   #1
Rewards Points: 29
How to test for leaks.
Ok so I moved the shower drain, ( made shower bigger). How do you check for leaks. Other than filling trap with water, that will work for two joints. Would like to check the joints at short extension. I'm confident it would not leak applied glue to
Pipe and socket. Mostly curios how to check if it had to be proved out to inspector.
Thanks for any and all comments,
Phil
philmy is offline   Reply With Quote
Old 02-02-2013, 09:54 PM   #2
Cap it with a gauge and air valve, something like 6 pounds for 8 hours. Do not remember. Now you would have to close off every fixture and vent in the whole system.
paintdrying is offline   Reply With Quote
Old 02-02-2013, 10:25 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 994
Static water test, find the main plug it with a test plug and fill the system with water at its highest pre flood level. what you simulate is a stoppage.
or you install a test tee after your last connection insert test ball past the last joint raise the drain 5 feet and fill with water. water collum test
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
TheEplumber (02-02-2013)
Old 02-02-2013, 11:00 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 568
Since very few fittings are altered, I would get away with a "running test". Stick a garden hose in there and run water as fast as the pipe will handle.
Standard test would be a 10ft water column(4.8psi)
I need to test a cable for a kitchen range justplumducky Electrical 4 10-21-2012 11:23 PM
Hot Tub GFCI Test Button Not Tripping Breaker a2zunknown Electrical 7 08-20-2012 07:49 AM
light receptacle vs. switch test device amakarevic Electrical 5 03-23-2012 05:15 PM
smoke test & combustion test?..what to look for?? millerheater HVAC 0 11-27-2010 10:44 PM
New test being conducted! Still hvac issue! MrShadetree0222 HVAC 24 10-21-2008 10:44 PM
