Old 01-12-2013, 01:19 AM   #1
How to sweat Oatey valve without destroying it
I have the Oatey 38530 washing machine box that I like to install this weekend. The valves are designed for sweat connections but they have a plastic hub on them - I would think the hub would be removed for sweating but applying some force to it did not unscrew it from the hub. I have sent an e-mail to Oatey tech support but have not received a reply, so any help from the forum would be welcomed.
euroboy is offline   Reply With Quote
Old 01-12-2013, 08:40 AM   #2
Master Plumber
Javiles's Avatar
They do come apart, or just pre sweat a female adapter to the pipe at least six inches or more then screw it on to the nipple, now your next solder joint should be fare enough from the plastic to avoid melting it.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is online now   Reply With Quote
Old 01-12-2013, 09:15 AM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Either slide/ unscrew the plastic piece outa the way, or use the Threads, insteada sweatin' it...
Old 01-12-2013, 02:15 PM   #4
Thanks for the reply. I took a closer look at the valve and it does look like it is a press fit - is this correct and would I* have to push the plastic part off as suppose to try to unscrew it.
The wall will be finished with tiles so I want to sweat the connection and avoid possible leaks in the future - as well I plan to turn the valves off when not in use so I like them to be well seated in the plastic hubs and not have any play.
Old 01-12-2013, 03:11 PM   #5
The faucet or valve should be in the open position before soldering/sweating.
If possible, wrap a few layers of cloth or absorbent paper around the metal between where you are soldering and the plastic components and soak this with water.
Electronic solder (60/40 or 62/38) has a lower melting point compared with plumbing solder (50/50 or 40/60) and this reduces the chance of damage from soldering heat.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 01-12-2013, 03:53 PM   #6
Roofmaster
It also has a rosin core that can pinhole and cause leaks, as far as I know. Ive never used it for plumbing for that reason. He should just use the drop eared threaded Shower L's
" A lot of men build things, and a lot of things fall down "
Old 01-12-2013, 04:03 PM   #7
call me E
TheEplumber's Avatar
Wrap the brass nipple in a wet rag, use a fine flame on your torch. Heat the pipe first then move the torch to the fitting and solder quickly. Apply no more heat then necessary. You can also Clamp it in a vice- it will serve as a heat sink
The Following User Says Thank You to TheEplumber For This Useful Post:
Bondo (01-12-2013)
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 02:24 PM
Mixer valve to transfer valve installation CarlV Plumbing 0 09-13-2011 12:28 PM
Double Check Valve installation (and a few other questions) secutanudu Plumbing 0 04-17-2009 08:42 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
