How Stop Whining Noise From Bathroom Faucet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-30-2012, 07:46 PM   #1
How stop whining noise from bathroom faucet?
Can anyone help me get rid of this annoying squealing noise from my Kohler Ellington widespread bathroom faucet? It's much worse on the hot side, but it occurs on cold too, though not always. It gets higher in pitch with more water pressure. It usually goes away after a minute or two.
I've tried a LOT of things to resolve the issue, nothing is working! Here's a few things I have tried:
- Removed the aerator (which is new, anyway)
- I did not remove the cartridge, because I'm not sure how on this faucet. But instead, I REPLACED the entire hot water valve/handle assembly, including its flexible hose, with another one just like it.
- Checked the T-connector for the hot/cold hoses for signs of blockage. It has a new washer.
- Opened up the faucets in the house, turned off master valve to let air out
- Tied down the hot water pipe with metal straps, so it isn't loose in the wall
I don't recall any such whining noise with my previous faucet. Is the Kohler just a poor design; I find that hard to believe? FWIW, there are two points on this design where the openings are reduced. But it appears to be part of the design (it is the same on both sets of faucets) so I can't change that.
One is in the faucet itself. It's behind the aerator, it looks like a permanent washer, so it restricts the flow of pressure. But it can't be removed. I believe it's there to allow the aerator to sit snugly against it. The other is under the hot/cold valve, where the hose fits. The hole there is 75% closed by a metal piece, that is permanently fixed.
Morris C. is offline   Reply With Quote
Old 09-30-2012, 08:42 PM   #2
Rewards Points: 582
did you rule out your shut off valves ...open faucet while its running shut off valve and reopen it....see if anything changes...
Old 09-30-2012, 09:37 PM   #3
That was #4 on my list: " Opened up the faucets in the house, turned off master valve to let air out "
Old 09-30-2012, 09:56 PM   #4
is this a new faucet? if so just return it. the restriction you mentioned is prob the source. close the shutoffs to limit the amount of water that you can get. you might have to go to a different faucet. i used to hate installing kohler faucets.
Old 09-30-2012, 11:57 PM   #5
SOLVED! (More or less...)
No, it's not a new faucet, it's probably a couple of years old, so can't return it (nor do I want to, because there's no other who's style I would prefer). I've already tried lowering the pressure, that did not eliminate the problem. The restriction I mentioned in the faucet and the brass hot/cold valves is part of the design... the Ellington gets generally good reviews, and since I don't see others with the same problem, I'm going to assume it isn't the design of the faucet itself. In fact, I more or less solved the problem, read on....
I'm fortunate to have a second identical faucet system to play around with. Since swapping out the hot valve with another did not work, I kept the second hot valve installed, but swapped out the spout with my second spout. That definitely seemed to make a difference. The whining on the hot valve became more of a humming noise, and this noise was lower than the noise of the water flowing. So not as annoying. Then I realized it was really vibration-based, and I could locate the vibrations to the hot water hose, around where it is connected to the T-connector. Shifting angle of the spout and consequently the position of the two water-mixing hoses underneath, changed the frequency of the vibrations and humming noise.
So I have now reduced the humming noise to a barely perceptible level, by wrapping a generous amount of teflon tape around the end of the flexible hose that goes into the hot water side of the t connector.
I hope this helps someone, because all of the research that I did beforehand on faucet noises, nothing mentioned this! Most said it had to be a washer, or vibrations from the water pipes.
Old 10-01-2012, 05:48 AM   #6
DIY staff
Rewards Points: 7,174
If it has a flexible feed line---perhaps that is the source of the noise----a kink---play with the lines--straighten the bends as you listen to the noise.
Morris C. (10-01-2012)
Old 10-01-2012, 03:43 PM   #7
SOLVED PART 2: YES, you are correct. I just figured that out a few minutes ago, that the problem is for sure coming from the flexible hoses that connect to the t-connector. Turns out the problem was not exactly "SOLVED" by changing the spout for another one. Once I installed everything correctly, there were still humming noises. (The HOT side had actually reduced to an acceptable level, but now the COLD side was almost whistling like a tea kettle!)
I think I finally did solve the problem, with a twist tie! I pushed the two hoses upward, so they create less of a bend, and held them in place with a twist tie hanging from the t-connector. The result is, I can barely hear traces of the noise on either hot or cold.
I can't believe I spent two days taking absolutely everything apart, redoing the plumbers putty etc etc., and all I had to do was fit a twist tie, without removing anything! D'oh!
The Following User Says Thank You to Morris C. For This Useful Post:
oh'mike (10-01-2012)
Old 10-01-2012, 08:44 PM   #8
DIY staff
Been there---why do you think I guessed the answer?
No flow from bathroom faucet Baylark Plumbing 1 02-26-2012 08:37 AM
leaky bathroom faucet; how do I change washer yummy mummy Plumbing 21 01-28-2012 02:13 PM
Leaky bathroom faucet Limner Plumbing 3 11-01-2010 02:13 PM
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 10:48 PM
Hear a Banging Noise from Bathroom Fan When its Windy wjk7320 Building & Construction 13 09-12-2007 11:13 PM
