How To Stop Drops Of Water At Tank Top Receptacles? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2012, 04:26 PM   #1
Rewards Points: 71
how to stop drops of water at tank top receptacles?
Installed Lowe Whirlpool 40 Gallon Gas water heater.
Having small water drops at both input cold water and output hot water pipe connector joints at the top of water tank. This tank has two holes on top with 3/4" threaded female receptacles for cold water input hot water output.
Tried different stainless steel hoses and plastic breaded hoses, using male+male adapter then female fittings, or just male fitting hose;
also use either and both Teflon tapes and Teflon pipe dope.
But slowly over night small drips of water coming out from the joint at top of tank.
We swap with many different hoses, finally, the least water comes out is the male fitting plastic breaded hose directly screwed into the tank receptacles.
How to stop this drip of water coming from these joints at the top of the tank? Thank you.
how to stop drops of water at tank top receptacles?-dscn2728.jpg   how to stop drops of water at tank top receptacles?-dscn2731.jpg
young707 is offline   Reply With Quote
Old 08-20-2012, 04:38 PM   #2
Rewards Points: 1,452
Looks like you did not use enough Teflon tape. Experts suggest at least 4-1/2 wraparounds.
Old 08-20-2012, 05:00 PM   #3
Rewards Points: 71
Yes, I use one layer of Taflon tape, from tip all along the threading. I cannot use any thicker than one layer, otherwise it just would not goes in.
I am concern with the soft plastic receptacles on top of the tank from over tightening. Any advice?
Old 08-20-2012, 11:04 PM   #4
Rewards Points: 71
can I insert the dielectric nipple (3/4" MPT x 3/4") into the top of the inlet and outlet of the tank using some kind of thermo resistant epoxy or glue of permanent potting to the threaded female receptacle?
Old 08-20-2012, 11:13 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
Not recommended
Use 3/4"x3" long dialectic nipples. then attach your flex lines to that.
Use teflon pipe dope on top of 3-4 wraps of teflon tape. Make sure to apply the tape in the same direction as the threads so it won't unravel while screwing in the nipples.
Old 08-20-2012, 11:32 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Try this stuff
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following 2 Users Say Thank You to plummen For This Useful Post:
TheEplumber (08-20-2012), young707 (08-22-2012)
Old 08-22-2012, 06:41 PM   #7
Rewards Points: 71
thank you (found at both Home Depot and Lowe's)
hot water tank question? guest Plumbing 5 12-13-2011 10:24 PM
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Concrete tank for solar water preheating? Badfish740 Building & Construction 5 03-09-2010 09:20 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
