How To Solder A Pipe That Is Dripping - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2008, 12:00 PM   #1
DIY Expert in Training!
How to solder a pipe that is dripping
I needed to cap off a line so I can continue my demo. Shut the water off but it was the lowest point in the house so it kept dripping. I am sure there are other ways but here is my wife's idea...we took a hanger and a strip of t-shirt. I used the hanger to push the material into the pipe about 18". I then got the pipe ready with flux, turned on my torch and pulled the hanger and shirt out. I soldered quickly so it wouldn't get water near the connection. Worked beautifully! I did use a strip of tshirt and kept some in my hand so it wouldn't get stuck.
gone_fishing is offline   Reply With Quote
Old 01-19-2008, 12:08 PM   #2
not a total Newbie
I've "heard" that you can use a wad of bread to do the same thing -- breaks up naturally eventually (but it will clog up your aerator on your faucets thinking you did something terribly wrong...ask me how I know ).
space_coyote is offline   Reply With Quote
Old 01-19-2008, 12:11 PM   #3
concretemasonry's Avatar
Rewards Points: 2,654
White bread (no crusts) stuffed into the line will also stop the water long enough for it to be soldered.
The bread then will dissolve or break down enough to go out through the outlets without clogging screens.
concretemasonry is offline   Reply With Quote
Old 01-19-2008, 12:18 PM   #4
I thought about the bread but didn't do this because:
1) No white bread in the house
2) Worried about it being in the water supply somewhere.
Old 01-19-2008, 06:37 PM   #5
Don't know it you're tieing back into the capped
line, but another option would be to sweat a thread/sweat fitting on.(ex. male / female adapter)
That way you can still pull the rag out of the line and then screw on a cap or plug.
It also helps when soldering so you won't build up pressure and blow the solder out of the joint.
Fitter is offline   Reply With Quote
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
