Old 04-08-2009, 04:23 PM   #1
Default How to solder 2mm nuts
I have a need to solder 2 or 3 nuts on top of each other to form a tower. I can solder copper pipe and electronic equipment, but when I try to solder the nuts together, the solder just balls up and rolls away. I have tried a small torch, 60 watt weller and 100 watt gun to no avail. Can anyone teach me how to solder? Thanks
DIYCUB is offline   Reply With Quote
Old 04-09-2009, 08:05 AM   #2
You may need to grind off any coating on the nuts, to bare metal, and don't forget the flux. It may take more heat than your guns can deliver. The metal must be hot.
Old 04-09-2009, 10:45 AM   #3
I would not use a soldering iron or the Weller gun even if it is 300 to 500 watts I don't think you will be able to heat it evenly. Use what you would use for copper pipe. As mentioned above be sure any coatings are removed and use flux. Not getting the metal hot enough is the most likely problem. We often get the solder hot enough to melt by heating the solder as the material is heated but the material is not hot enough to allow the solder to flow. Try keeping the solder away from the heat source until the material is hot enough. "Test" by just touching the material with the solder momentarily every few seconds until it melts when contact is made. Be sure you are not melting the solder with your heat source. You want the heat in you material to melt the solder. Another method is to put small bits of solder on the material and heat until the solder melts and "flows" into place. If the solder does not flow - no flux/wrong flux or not clean or not enough heat.
RegeSullivan is offline   Reply With Quote
Old 04-09-2009, 11:21 AM   #4
Thanks for your replies. I used a mini butane torch and the nuts were red hot and when I touched the solder to the nuts, it melted into a ball and rolled off. Does it need to get hotter? I believe the nuts are nickle plated.
Old 04-09-2009, 01:06 PM   #5
Red hot is too hot. The solder should just melt when you touch the material you are soldering. I really don't know if you can solder nickle but even if you can I would grind off the plating and solder to the base metal.
More On This Topic
Hey everybody Don Golden with Expert Village and we're moving on with our copper piping. I'm going to show you now what you need to join these in everlasting matrimony. What we are going to do is we are going to use what is called flux paste. This is a... Read More »
I'm D.J. Poye, professional jeweler and gemologist and I'm here today on behalf of Expert Village. Okay, now what we'll do is, I need to cut a few pieces of solder, this is Antimony solder, it doesn't have the copper in it. So it really, really is a... Read More »
On behalf of expertvillage.com, my name is Allison at Western Art Glass. I'm still in process in soldering my way cool sun catcher. In the last step we did what is called a tact solder. The thing is all held together now so now I can apply flux to the... Read More »
Hi! This is Diana for expertvillage.com. We have our torch going, we have our piece of solder and now we are going to solder this piece together. We have the flux on it, hold the flame down onto the metal and touch the solder to it. When the solder gets... Read More »
Hi! This is Diana for expertvillage.com and we are going to solder the second part of our copper tubing plant hanger. This is the little ring we are soldering right in the middle of the front and that is going to hold your ceramic pot. I've got flux on... Read More »
How To Solder Copper Pipes thekctermite How To Guides 65 11-04-2009 10:14 AM
Solder not working it's way to where I need it. tripower Plumbing 25 02-24-2009 05:25 PM
When soldering copper, what causes the solder not to "suck in"? Piedmont Plumbing 10 10-25-2008 10:59 AM
Solder for hot water heating system junkcollector Plumbing 2 09-12-2008 08:09 PM
Impact gun not removing lug nuts n0c7 Tools 10 06-18-2008 05:20 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
