How To Slope Pvc Pipe With 90's - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-26-2010, 06:58 PM   #1
how to slope pvc pipe with 90's
To obtain 1/4" pitch in my waste line do I glue the pipe into the 90 degree hubs at an angle? If not, how do you gain 1/4" pitch? The 90's will be at different heights?
gregandersen is offline   Reply With Quote
Old 08-26-2010, 08:47 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 814
If you are installing the 90's on the horizontal then rotate the fitting slightly to match your grade. If going horizontal to vertical, or vertical to horizontal the fitting has enough play to allow for 1/4" grade
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Bernoulli's Principle, increase 3/4" pipe to 1-1/4" or 1-1/2" copper ChrisDIY Plumbing 14 09-18-2010 09:49 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
