How Should I Pitch My Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2010, 12:16 PM   #1
How should I pitch my pipe?
Installing a bathroom exhaust.
My duct is running horizontal for 7 feet and elbowing up 2 1/2 feet through the roof? The entire run is insulated.
If I slope away from the fan I'm afraid I'll have water/condensate sitting at the elbow. If I slope towards the fan I'm afraid I'll get dripping out of the fan.
Which direction should I pitch my horizontal duct?
buildjack is offline   Reply With Quote
Old 08-11-2010, 08:21 PM   #2
Registered User
Rewards Points: 4,888
Use 4", not 3". Use a timer. Insulate the fan box and ducting, with a vapor barrier. Use 45* elbows instead of 90*s. Use straight pipe, not flex. If flex- go 1 size bigger. Foil tape all joints, even the 45* individual ones against air. Read about the thicker walled abs pipe. Flex at the end of run has twice as much surface volume to trap water and reduces the air-flow by causing turbulence depositing more moisture on the pipe walls. Be sure the fan is rated for the bathroom. Be sure a back-draft damper is on the duct termination, not just the fan housing to prevent outside air into the pipe with moisture to condense even when fan is not operating.
http://www.pse.com/SiteCollectionDoc...S_Moisture.pdf
http://www.cbs.state.or.us/bcd/progr...commentary.pdf
http://www.efi.org/factoids/bathroom_sizing.html
http://homes.winnipegfreepress.com/i...article&id=702
http://www.rd.com/how-to-install-a-q...icle18312.html
I would pitch it straight from low to high. The farther from the fan, the less steep the angle because the air pressure is weakest there, most likely to deposit the moisture on the pipe walls.
Be safe, Gary
Old 08-11-2010, 10:10 PM   #3
I plan on doing it as you outlined - without all the insulation. The entire run is in interior (heated) space. Are you saying I should use ABS pipe instead of galvanized duct? What about PVC pipe? (I've never used abs pipe)
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 01:03 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 06:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
