How To Set Up Drainage For Water Heater In Middle Of House? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2009, 05:07 PM   #1
Rewards Points: 682
How to set up drainage for water heater in middle of house?
I have a water heater that is towards the middle of the house. The p/t valve has no drainage to the outside.
Do I just try to rip through multiple walls to run a drainage pipe to the outside? Or will the city allow me to just let the p/t valve drain to the floor?
This house was built in the 60's, I'm guessing code did not require the water heater p/t valve to drain outside in those days.
darsunt is offline   Reply With Quote
Old 10-18-2009, 06:42 PM   #2
DIY staff
Rewards Points: 7,174
More details--Where is the nearest drain?
There is a pump operated drain box that may do what you need.
It's little more than a plastic box with a little sump pump in it . Just route the drain line where ever you need to.---MIKE--
Old 10-18-2009, 07:45 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
I don't know of any code that requires the TPR to be drained out side.
It needs to terminate 6" above the floor into a pan or to a floor drain so that if if starts to leak someone call notice it and then get repaired.
You can get a pan for the WH and place a sensor in the pan that will set off an alarm to notify you.
The TPR is not a drain it is a pressure relief that open when either temp or pressure excedes the TPR non adjustable settings. Basically it opens so that the tank wil not explode. Draining it to the outside in cold ares and cause it to freeze if it start to release and also provides a nesting place for bugs and critters. I would not drain it to the outside.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-18-2009, 08:48 PM   #4
Rewards Points: 682
All the tp valves I've seen have long pipes draining to outside the building, so I assumed that was the code. This is CA, maybe codes are stricter here?
But I would be happy to run the drain from the valve to a pan on the floor. It would be so much easier.
Old 10-18-2009, 09:19 PM   #5
Rewards Points: 560
Here is a link to CA plumbing code
http://www.iapmo.org/Pages/californiaplumbingcode.aspx
CA code is a little different
Chapter 5, 508.5 states that Discharge from a relief valvle into a water heater pan shall be prohibited
Chapter 6, 608.5 states that the relief drain must go to the outside or to other approved locations.
Other locations to me would be an air gap type connection. Like a floor drain
I would talk with local codes. A jurisdiction can change the code to it's city requirements
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
77amp Tankless Water Heater on 150amp House??? deeze Electrical 29 08-18-2009 01:37 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 08:51 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
