How To Run Fridge Water Line Under Kitchen Floor? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2006, 04:33 PM   #16
Rewards Points: 528
Travishume,
I suspect the installer used a strong magnet. If you can attach a short piece of thin steel wire to the supply line, You might be able to slowly drag it underneath the floor boards. You will need a very strong magnet and some imagination in connecting the steel wire to the line so that the wire moves freely on the supply line. This will allow the attraction of the magnetic effect to pull the wire up againt the floor boards as you slowly lower the line into the hole. Sometimes beaded chain may be better then wire. Good Luck.
rjordan392 is offline   Reply With Quote
Old 09-21-2006, 04:37 PM   #17
Oh. Interesting idea. Didn't even consider something like that.
Thanks for the idea.
travishume is offline   Reply With Quote
Old 09-21-2006, 06:39 PM   #18
Rewards Points: 528
Put a loop or hook on the end of the wire so that you can use another wire to grab it.
Old 09-23-2006, 12:05 AM   #19
renovations
Cut bigger holes, tie the pipe to a gerbil.
Bonus is offline   Reply With Quote
Old 09-23-2006, 08:15 AM   #20
Journeyman Plumber
Ron The Plumber's Avatar
My answer stands, without access to under that floor it's not going to happen.
Here is an idea to think about, tap into the source from another place, like water heater location, run the line through the attic, over to the fridge wall, and down the back side from above, two small hole in the ceiling, now take a molding strip thicker then the 1/4" tubing and a router, route out the middle and use it to cover up the pipe comming down the wall. Problem solved, this is only if you have attic space.
Ron The Plumber is offline   Reply With Quote
Old 09-23-2006, 04:52 PM   #21
I have the exact same problem. I was wondering if you could run the water line up to the attic and down the other side? If I did hire a plumber, does anyone have any idea how much it would cost?
diyrealtor is offline   Reply With Quote
Old 09-23-2006, 04:55 PM   #22
Journeyman Plumber
If it's easy to access the attic, a couple of hours time, say around $199.99 and you only neeed to run 1/4" copper line.
Old 09-23-2006, 05:06 PM   #23
Thanks Ron!
Old 09-26-2006, 07:51 AM   #24
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
One of the first things I suggested was to tap another source. Apparently the poster says there are no other water sources on that side of the house at all
J187 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Help me locate a water line for my icemaker, PLEASE! curls00 Plumbing 11 07-23-2007 09:35 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Adding a new water line to dishwasher and fridge? PMichaud Plumbing 18 01-05-2007 07:00 PM
Tapping a water line for fridge Statecowboy Plumbing 6 10-12-2006 11:45 AM
