How To Rotate This T Joint On Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2010, 05:24 PM   #1
hobbsInVancouver
How to rotate this t joint on drain?
Hi. The first step in my reno of our mudroom will be to move the laundry sink. It drains through a T joint currently coming off the main drain pipe to the right. I want it join the same pipe from the left. Pictures attached.
So, is this something a diy'er with little plumbing experience can do? What's the best plan? Do I loosen the T joint with a blow torch, rotate it then dose it with fresh solder? Or is it better to cut the T joint out and fasten something new in there, pex or a new copper joint. The vertical drain pipe is coming from the kitchen sink, if that matters.
I'm sure I can handle moving the hot and cold feeds, I plan to use sharkbite connectors with pex tubing, only moving the sink about 4 feet.
Thanks much, any advice is appreciated.
c
hobbs in vanvouver is offline   Reply With Quote
Old 02-13-2010, 08:09 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
Redo with PVC
The easiest way is to cut out the joint and redo it all with PVC. Cut the vertical pipe a couple of inches above and below the tee joint, and take the whole joint out. Then redo everything with PVC, which is cheap and MUCH easier to work with than copper for DWV, and you can connect the plastic to the existing copper using banded couplings, which tighten by screwdriver. So you will not have to solder anything.
adpanko is offline   Reply With Quote
Old 02-13-2010, 09:07 PM   #3
hobbsInVancouver
Cool, that's what I was hoping to hear. Much appreciated adpanko. Cheers, c.
Old 02-14-2010, 02:54 PM   #4
Remodeler
adpanko's Avatar
Rewards Points: 150
One final thought - I just noticed you said you are moving the sink about 4 feet. When you redo the horizontal pipe running into the tee, use 2" PVC, not 1.5" because code says you can only run 1.5" 2 feet (I think it is 2 feet; might be slightly more or less, I'd have to check) without having a vent for the fixture you are draining. 2" pipe gives you a lot more distance before needing a vent. Something like 8 to 10 feet I think (again, I'd have to look up the specifics, but I know it is more than what distance you need from looking at the picture). It looks like you currently have 1.5" copper draining into 2" copper. Redo it all w/ 2" PVC and you're fine.
Old 02-14-2010, 11:55 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
you need to keep the same material in that vertical stack so that means sweating in a new 1 1/2" copper santee and a couple copper slip couplings.im not sure what your local code calls for on reventing you might want to move your sink closer to avoid it.Anyway run your waste arm in 1 1/2" pipe it can be pvc attached to a short stub of copper coming off the santee with a no-hub type coupling(no fernco ) going to 2" pipe would be funneling which is ilegal in most places.
plummen is offline   Reply With Quote
Old 02-15-2010, 10:01 AM   #6
Rewards Points: 346
For my benefit, can you explain why it would be funneling? It looks like a 2" stack so I don't see the problem.
Thanks,
Rege
RegeSullivan is offline   Reply With Quote
Old 02-15-2010, 10:05 AM   #7
plummen's Avatar
i was referring to tying it back into the existing 1 1/2" san tee,youre absolutely right it would be fine if he can find a 2x2x2 san tee to stick back in there.
Old 02-15-2010, 07:24 PM   #8
biggles's Avatar
the best thing there is it isn't pressured water running just atmosp.drain water thru it.wire brush all 3 soldered joints before lighting the torch and paint them once around with some flux.keep the torch about 2" off the flat part of the tee waving it once or twice to the fitting to get turned on .set up a channel locks to fit the tee and give it a slow twist to the new direction then wipe all 3 joints with the solder...you done..........
Old 02-16-2010, 10:35 PM   #9
Remodeler
adpanko's Avatar
Rewards Points: 150
Do you really have to have the same material on the stack? When I redid my kitchen two years back (in NJ), the plumber basically did exactly what I was describing for this fellow to do - cut out a copper tee from a 2" copper stack, replumb the whole section of stack with PVC attached via banded couplings, etc. It all passed inspection with no comment about the change in materials at all. Our town goes off of the 2006 NSPC.
Old 02-16-2010, 10:55 PM   #10
plummen's Avatar
You run into differant expansion rates of the differant materials ison reason,the biggest problem ive seen arises when somebody chops out a piece of cast iron from a stack and substitutes pvc which in turn ends up supporting the weight of all the cast iron above it.I guess it alldepends where you are and how bad the inspector wants to complain!
pvc drain pipe joint leak nytstyk Plumbing 2 12-28-2009 01:05 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 02:46 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 01:29 PM
