Old 12-26-2011, 11:48 AM   #1
How to Replace shower shut-off valve
The right shut-off valve is leaking. The valve leaks even when it is completely closed and also leaks when it is open to the max.
This is a picture of the entire faucet and valve system.
I haven't been able to find a similar valve at Home Depot.
How would you recommend removing and replacing the valve?
Thanks!
Cindy_Home is offline   Reply With Quote
Old 12-26-2011, 12:13 PM   #2
MarginallyQualified
Assuming you actually need a shutoff valve (I doubt that)...
you should be able to rebuild what you have with new packing and maybe a new seat washer.
If not, the simplest thing is probably to replace it with another shutoff valve.
Probably located somewhere else and with some repiping work as well.
hth
I misread your post but I'll leave this stuff anyway:
A new tempering diaphragm might fix the shower valve but that's probably not worth the effort to find out.
By following the directions that come with the new MOEN or DELTA you buy.
As you have most of the wall torn open already... you're most of the way there.
This will also make fixing the broken off shower arm problem easier too.
hth
Old 12-26-2011, 04:04 PM   #3
Should we replace the whole faucet and valve system because the double valve system is the old style?
How to replace the trigger valve on a Bostich Nail Gun. brokenknee How To Guides 6 03-21-2012 02:26 PM
New shower valve, no hot water? Chris112 Plumbing 0 03-19-2011 07:21 PM
Where the heck is the shower shut off valve? Monika2024 Plumbing 7 12-17-2009 03:19 AM
I thought I put it back together properly: leaky shower valve (Matco-Norca) shuuy Plumbing 1 06-18-2009 11:44 AM
Replace a shower valve with no access panel ALfromSTL Plumbing 11 12-12-2008 09:56 AM
