How To Replace Dorf El Toro Washer - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-15-2012, 02:26 AM   #1
Eos
How to Replace Dorf El Toro Washer
I thought the washers are worn as it is not easy for parents to tighten up and it always driping. I tried to uninstall the tap but cannot go further. Need instruction urgently. Thank you very much.
Eos is offline   Reply With Quote
Old 01-15-2012, 05:14 AM   #2
DIY staff
Rewards Points: 7,174
Those escutcheons unscrew --counter clock wise--you may need a rubber strap wrench to do this without damage.
Old 01-16-2012, 07:14 AM   #3
Eos
Thanks. Oh'Mike. What does word "escutcheons" mean? How can a rubber strap wrench hold the bell shape cap tightly? One of my friends said it needs to be done from the bottom of the basin (unscrew something underneath the basin, I touched there is something can be unscrewed). I don't know what to do now.
Old 01-16-2012, 07:35 AM   #4
DIY staff
The bell cap is what I meant by escutcheon ---You don't need to do any thing under the sink--that is held in place by a nut on the top--under the bell--
Once that bell is off post another picture---I never heard of that brand--I hope you can get repair parts--Mike---
Tags
dorf , el toro , replace washer , uninstall
Replace Washer drain hose lgreen33 Appliances 5 01-01-2012 10:19 PM
Washer Drain Pipe Install somewhatsketchy Plumbing 0 10-10-2010 11:13 AM
Washer water supply valves won't turn jerome8283 Plumbing 2 11-01-2009 09:38 AM
Pressure Washer Manifold Replace DIY JIM Tools 3 10-13-2009 07:50 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
