How To Replace Bathtub Drain With Out Removing Tub? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2012, 11:29 AM   #1
how to replace bathtub drain with out removing tub?
Is there a way to replace a bathtub drain without removing the tub, I had this tub redone in 2010 and now it appears to be leaking at the bottom of the trap?
frank snell is offline   Reply With Quote
Old 10-09-2012, 11:50 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 556
Yes, if you have access to the end and/or bottom. I can't remember pulling a tub to fix a leak. I have damaged a lot of walls and ceilings though
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
frank snell (10-10-2012), oh'mike (10-09-2012), VIPlumber (10-09-2012)
Need a cheap fix to slow bathtub drain need help Plumbing 11 04-26-2016 09:11 AM
I clog my bathtub drain with hair-solution works for me gailquilter2 Plumbing 6 07-02-2012 08:20 PM
Bathtub drain in a new basement bathroom flynryn Plumbing 1 05-28-2010 05:00 PM
Can't fix bathtub drain KimberlyS06 Plumbing 3 05-08-2010 11:43 PM
Removed plunger type drain assembly but bathtub still wont drain. Please help lydiarosestiles Plumbing 3 05-01-2010 11:59 AM
