How To Replace 2" ABS Elbow - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-26-2011, 07:30 PM   #1
Rewards Points: 518
How to replace 2" ABS elbow
I discovered a drywall screw has punctured a 2" ABS elbow. What is the best way to replace this? I've worked with PVC and ABS a bit before so I'm familiar with working with it but I've never attempted to replace a piece in the middle of a run as I know I probably won't be able to glue and twist both ends at the same time.
n0c7 is offline   Reply With Quote
Old 10-26-2011, 08:08 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
Although its nice to be able to twist the pipe in as you glue its not mandatory. Get yourself a new 90, a pair of couplings and some pipe. Cut out pipe as needed, glue on the couplings to the existing pipe ends and build to the new 90. Make sure to apply glue liberally to the 90 and pipe ends and push it on. Wipe away excess glue and your done.
The Following User Says Thank You to TheEplumber For This Useful Post:
plumber666 (10-27-2011)
Old 10-26-2011, 09:02 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Make sure there is enough flexibility in both pipes so that you don't end up stuck. If they won't move much, you might need a no-hub coupling on one side.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
TheEplumber (10-26-2011)
Old 10-26-2011, 11:28 PM   #4
Rewards Points: 518
Looks doable. Is a rec saw the best way to get a clean cut in a tight spot?
Old 10-27-2011, 09:18 AM   #5
Doing it myself
Alan's Avatar
I like using this for tight areas. http://www.tools-plus.com/stanley-20-220.html
Reciprocating saw can be hard to get a straight cut especially if it's a tight area.
Journeyman Plumber
Old 10-27-2011, 04:29 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,260
Buy the cheapest ABS fitting you can find, size or type fitting does not matter. Use a very coarse file and grind off about 3 tablespoons of ABS filings. Clean the spot with the hole with MEK solvent. Mix MEK with the ABS filings to a thick slurry(thicker the better). Use the slurry to patch the screw hole.
Or just hit it with a dab of silicone.
The plumbers will hate me for this.
Either method will outlive you.
BTW, I assume this is a DVW connection.
Coastal South Carolina
Old 10-27-2011, 04:46 PM   #7
Busy DIYer
picflight's Avatar
Rewards Points: 150
I would try this first.
picflight is offline   Reply With Quote
Old 10-27-2011, 05:33 PM   #8
Rewards Points: 340
same here, esp. for a small hole from a screw. there are also some heat activated welding pastes available that will work as well.
NitroNate is offline   Reply With Quote
Old 10-27-2011, 08:05 PM   #9
Doing it myself
Alan's Avatar
Option 1 : Buy fitting. Grind it in to pieces. Jerry rig the crap out of your plumbing.
Option 2 : Buy fitting. Fix your problem properly. Less work, better results.
I can't believe you would recommend doing something like that.
Replacing the elbow isn't that difficult. Just do it right.
Journeyman Plumber
Old 10-27-2011, 10:14 PM   #10
A "Handy Husband"
rjniles's Avatar
I said the plumbers would hate me
Old 10-27-2011, 10:52 PM   #11
Rewards Points: 518
Thanks for all the suggestions. I cut out the elbow and replaced it.
Old 10-27-2011, 10:55 PM   #12
Plumber
Rewards Points: 904
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 02:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 07:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
