How To Repair An Oil Fuel Line That Has A Bent Where It Meets The Conrete Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2011, 09:31 AM   #1
how to repair an oil fuel line that has a bent where it meets the conrete floor
SOmehow I accidentally bent the fuel line that comes from the concrete floor and connects to the furnace. How do I go about repairing that line?
Rolivel is offline   Reply With Quote
Old 01-24-2011, 09:42 AM   #2
Rewards Points: 468
If it is right at the concrete floor lever with that. I guess you are going to have to chip out the crete tell you can cut it off at the bend and flair the end and use a coupling and flair the other end . connect togother. Flair i belive is the best wat to do this. I wouldn't use any flaime near the line but keosene is low flash point but i woundn't do it. Flair is the only way to do it safe. my 2 cents
del schisler is online now   Reply With Quote
Old 01-24-2011, 09:46 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
You would have to chip a lot of concrete to get the flaring jig on the pipe coming up from the concrete. I would chip out enough concrete to put in a compression fitting. Do not bury the fitting in concrete, leave it exposed.
Coastal South Carolina
Old 01-24-2011, 03:59 PM   #4
Licensed Master Plumber
chip a little and go with a 3/8 soldered coupling. Yes the oil will burn a little but not enough fire to worry about.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 01-24-2011, 07:42 PM   #5
Civil Engineer
Rewards Points: 4,520
I assume you have a copper line. I believe that current code for buried copper requires that the line be double pipe. At least that is the way it is in my town. I replaced my buried copper line with an above the floor line. It may be less trougble to replace the entire line with a new, double wall pipe above the concrete, than to try and fix the old line.
Daniel Holzman is online now   Reply With Quote
hook up ice maker line. already have a valve on the floor behind fridge but...3/8" bakchoi Plumbing 5 11-25-2008 07:59 AM
fuel leak where filter line meets tank line sonofthetonsured Automotive Repairs 2 04-22-2008 09:11 AM
air in fuel line pingers7 HVAC 2 01-28-2007 07:41 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 08:10 AM
