Prev Previous Post   Next Post Next
Old 01-31-2008, 02:05 AM   #1
bofusmosby's Avatar
Default How to repair a hole in cast Iron pipe?
I am getting ready to replace the toilet (seal leaking) in my house, so I went under the house to check out the plumbing, so I know what I am up against. Everything I have done on this house has turned into a big job. You know, the "can of worms". Well, the toilet I am replacing is one of the newer types, so I saw from under the house, there was PVC going from the under-side of the toilet, going into the old cast-iron pipe about 4-5 inchecs below the floor.
About 3-4 inches above the ground, I noticed a small hole in the cast iron pipe. It looks to be about a perfect 1/4 " hole, that looks to have been drilled. The water isn't flowing out the hole, because it looks like there is some paper clogging the hole, so the water is just slowly seeping, with a small wet spot surrounding the pipe going into the ground.
First, would there have been any reason for this hole to have been put there, and second, what is the best way to seal or plug this hole. Any advice would be greatly appreciated.
Thank you!
bofusmosby is offline   Reply With Quote
More On This Topic
Hello, My name is Mac and on behalf of expertvillage.com I am going to give you some tips on how to deal with the different kinds of fumes and smoke that you will encounter while you are doing arc welding. Now some of the gases that we use in MIG welding... Read More »
Arc Welding Types & Uses
Arc Welding Types & Uses by Expert Village
Hello! My name is Mac and on behalf of expertvillage.com I am here to discuss arc welding. Now this machine that I am standing beside here is a multi-process welding machine. It can do many different kinds of arc welding and I am going to give you a... Read More »
Hi! My name is John on behalf of expertvillage.com. In this video clip we will be discussing the proper clothing for arc welding. When arc welding, you need to make sure that you have an arc welding helmet with a shade of 10, 12 or 14. I personally use a... Read More »
Hi this is Fernando we are here with Expert Village going over how to maneuver around certain obstructions like cement. Here you could see we are here next to a fence and do to what is in the dirt we are not able to have a clear cut obstruction view of... Read More »
Hi I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're going to do some work for you today on Expert Village. So now Dave's got on the welding helmet and he's going to go ahead and tack the front of the pipe in... Read More »
cast iron hub handifoot Plumbing 1 12-17-2007 07:51 PM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 07:39 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 12:58 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 10:20 PM
Old cast iron pipes heather92 Plumbing 2 04-10-2007 10:36 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
