How To Repair Delta Mixing Valve (diverter Stem) - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2014, 06:24 PM   #1
Rewards Points: 260
How to repair Delta mixing valve (diverter stem)
The stem on my Delta mixing valve was initially leaking. It eventually fell out. It shoots a stream of water out, when it is in the shower mode. How do I repair the stem on the valve?
bluefitness is offline   Reply With Quote
Old 10-11-2014, 06:39 PM   #2
Rewards Points: 14,294
Only way I can see it leaking or coming out is if the packing nut came completely loose.
Contact Moen and they will send you a whole new stem for free.
As soon as it was leaking you should have removed the knob and tighten the nut.
Old 10-11-2014, 07:03 PM   #3
Rewards Points: 260
The second picture shows the stem I'm referring to. The spring shouldn't be visible. I can pull it out completely. It is a Delta mixing valve. Do they have this type of part at HD or Lowes?
Old 10-11-2014, 07:29 PM   #4
Rewards Points: 342
Looks like the diverter is shot. No biggy, easy fix.
Yes the big box, plumbing supply, or local hardware store may carry them. Take the old one with you. Call first and save a trip. If not, delta will send you one out. Just a suggestion.
Click on link for more info. Thanks.
link here
jmon is offline   Reply With Quote
Old 10-11-2014, 11:20 PM   #5
Rewards Points: 260
Thanks got it fixed
The Following 2 Users Say Thank You to bluefitness For This Useful Post:
jmon (10-12-2014), oh'mike (10-12-2014)
connect pex to Delta Multichoice shower only valve jonhayden Plumbing 13 01-12-2014 08:33 AM
stripped shower valve stem. smaleckar Plumbing 7 12-17-2013 05:02 PM
How to replace the trigger valve on a Bostich Nail Gun. brokenknee How To Guides 10 11-08-2013 12:25 PM
repair Mueller 3/4 inch Brass Stop and Waste Valve dadcarter Plumbing 3 03-02-2012 08:27 AM
Mixing Valve replacement mediaman67 Plumbing 20 03-02-2010 10:19 PM
