How To Repair Copper Toilet Riser - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By jmon
  • 1 Post By jkk
Old 01-09-2017, 01:32 PM   #1
jkk
Rewards Points: 233
How to repair copper toilet riser
Friend's 40 year old house has a copper toilet riser (located in lower, center of photo) that is corroded and leaking. The toilet fitting is directly next to the kitchen sink fitting. Seems like the easiest repair is to cut the horizontal kitchen drain pipe and to cut just beyond the toilet and kitchen drain fittings and replace with PVC 1/8 & Wyes.
Is a Fernco the item to use to join the PVC to the copper?
jkk is offline   Reply With Quote
Old 01-09-2017, 01:56 PM   #2
Rewards Points: 482
Re: How to repair copper toilet riser
Yes.
I'd use some pipe dope or PL urethane window and flashing adhesive on the Fernco.
clarenceboddick is offline   Reply With Quote
Old 01-09-2017, 02:19 PM   #3
jkk
Rewards Points: 233
I meant to ask ... Why would the riser corrode and not the other pieces?
Old 01-09-2017, 02:39 PM   #4
Rewards Points: 218
Water hardness, leaking over the years, moisture in basement air, etc., can cause premature staining and corrosion. Copper is notorious for this.
Are you sure it's not leaking from above and dripping down. 40 year old toilet, maybe the wax ring is shot, overflowing toilet or flange is cracked. Looks like a lot of water staining on the wood. Just a suggestion.
Bondo likes this.
jmon is online now   Reply With Quote
Old 01-09-2017, 02:46 PM   #5
Looks as though other peices have started to corrode also, could be something in the water, like an acidic pH. Would seriously consider redoing the plumbing, the scrap money from all that copper would probably pay for a majority
DoSomething is offline   Reply With Quote
Old 01-09-2017, 03:07 PM   #6
jkk
Rewards Points: 233
True enough but that doesn't explain why only once piece of the system has failed, especially a vertical piece.
Are you sure it's not leaking from above and dripping down. 40 year old toilet, maybe the wax ring is shot ...
The pipe actually has tiny holes in its wall so he's sure it's defective.
jmon likes this.
Old 01-11-2017, 07:57 AM   #7
jkk
Rewards Points: 233
On second thought, what I proposed involves cutting out a lot of good plumbing when the only bad piece is the riser.
If the lowest portion of the riser is intact, is there any way to just replace the riser? How much of the existing riser is needed to use a fernco and PVC to connect to toilet? Is there another device we can use to insert into the riser's fitting (after cutting riser off flush with fitting) and then connect to toilet with PVC?
Old 01-11-2017, 08:19 AM   #8
Rewards Points: 704
Once we cut into systems of that age we are often in for several condition surprises.
Old 01-11-2017, 09:22 AM   #9
jkk
Rewards Points: 233
True enough, but just in case I only need to replace the riser I'd like to know the best and easiest way to do that.
If only the riser is bad, but it's bad all the way down to the fitting, is there some adapter (e.g. special Fernco) that will allow us to get the new PVC riser attached to, and/or maybe inserted into, that copper fitting?
Old 01-11-2017, 06:35 PM   #10
Rewards Points: 1,770
A proflex fernco not the all rubber one.
Old 01-11-2017, 07:29 PM   #11
jkk
Rewards Points: 233
Like this one?
Kohler toilet repair McClure77 Plumbing 8 07-15-2015 03:00 PM
Toilet flange gap repair toiking Plumbing 5 08-18-2012 06:47 PM
Who should pay for toilet repair? Gabriel24 Plumbing 10 11-23-2011 10:11 AM
suggestions for repair of 1/2" copper line -see photo mycophile Plumbing 1 11-15-2011 06:21 AM
Toilet riser issue JJ2790 Plumbing 4 02-15-2010 11:31 AM
