How To Repair Bottom Of Rusted Out 10" Steel Pipe. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2012, 12:14 AM   #1
how to repair bottom of rusted out 10" steel pipe.
pipe transports water from springs to fields for irrigation. Pressure is <20 lbs. "Leaks" - some extend length of 20' sections. Width is variable to 4 to 5". I have considered wrapping pipe in fiberglass fabric and then coating with various products like polyester, epoxy, EPDM, TPO, Hypalon. Also thought about using 3M 5200 sealant to adhere 26 Gauge HVAC/stove pipe Galvanized Steel cover leaks. All are expensive! Anyone have a cheeeeep alternative other than replace line completely?
michael laffert is offline   Reply With Quote
Old 04-25-2012, 12:17 AM   #2
Rewards Points: 13,446
That would be like playing wack a mole.
Time to replace the line with PVC.
Or black plastic.
plummen (04-25-2012)
Old 04-26-2012, 09:19 PM   #3
Rewards Points: 582
Iam supporting joe on this one ....replace it....
old steel pipe buddy hathorn Plumbing 7 03-08-2012 10:16 PM
Repair Cast Drain Pipe strickja Plumbing 10 02-26-2012 10:31 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
