How To Remove Vinyl Adhesive And Foam Insulation? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2012, 02:48 PM   #1
How to remove vinyl adhesive and foam insulation?
Hi there!
I'm cleaning out the kitchen sink cabinet in my new apartment and found that the previous tenant/super used a combination of foam insulating sealant and felt-back sheet vinyl adhesive around the pipes under the sink. I found cans of both under the sink too.
I've been chipping away at the foam with a knife but haven't had much luck with the peanut-butter-looking vinyl adhesive.
Any ideas on how to remove the two?
Thanks in advance for your help!
dodan is offline   Reply With Quote
Old 02-05-2012, 02:51 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Try some acetone,now that trap on the other hand!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-05-2012, 03:44 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,732
Ayuh,.... Yer a Tenant,... What are ya doin' tearin' the place Apart,..??
The Following User Says Thank You to Bondo For This Useful Post:
framer52 (02-05-2012)
Old 02-05-2012, 04:28 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
As a landlord I'd ask the same thing. What are you doing. Try calling your landlord.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
Old 02-05-2012, 04:34 PM   #5
Rewards Points: 528
My thoughts exactly. could be the landlord did it.
framer52 is offline   Reply With Quote
Foam Insulation Questions - Please help kuj0317 Insulation 3 01-27-2012 07:31 PM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Adhesive for R MATT foam board captainrichhill Building & Construction 2 05-24-2010 05:40 AM
What adhesive to use for EPS rigid foam insulation creamaster Building & Construction 1 04-01-2010 07:00 PM
