How To Remove The Tub/Shower Faucet Lever Handle? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2013, 03:27 PM   #1
How to remove the Tub/Shower Faucet Lever Handle?
Hello! My Peerless bathtub faucet drips. See the picture
I have ordered the part Valve Cartridge but was unable to remove the Lever Handle. I first removed the Set Screw but I could not pull out the Lever Handle. Is the Lever Handle supposed to be easily pulled out after the Set Screw has been removed or I should remove something first or remove the faucet behind the wall? See another picture.
Please tell how to remove the Tub/Shower Faucet Lever Handle to replace the valve cartridge. Thank you.
compiler is offline   Reply With Quote
Old 03-29-2013, 03:46 PM   #2
Lord of Slums
Rewards Points: 1,974
Allen key
mj12 is offline   Reply With Quote
Old 03-29-2013, 03:48 PM   #3
Rewards Points: 12,856
If you have the screw out the hande should pull right off.
Over time some corrosion may have set in so some wiggling and a firm tug should get it off.
Old 03-29-2013, 05:21 PM   #4
What to do next after the Lever Handle has been pulled out?
Hi, I have eventfully pulled out the Faucet Lever Handle. Now I need to handle that copper sleeve. Should I counterclockwise that copper sleeve before I can pull out the cartridge? See the picture.
Please advise how to pull out the cartridge. Thank you.
Old 03-29-2013, 08:04 PM   #5
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
unscrew the brass nut,top arrow ccw be careful if the whole body of the valve turns you may kink/cause a leak to the 2 - 1/4" copper lines.If u can use a back up wrench or cut it off if won't come loose.
wctekkk is offline   Reply With Quote
Tags
tub faucet cartridge
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 05:02 PM
Replacing outside faucet handle bucksone Plumbing 1 09-27-2012 10:11 PM
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 03:13 PM
Faucet handle faces the wrong direction. diyntn Plumbing 1 04-22-2009 09:09 PM
Faucet Drain Lever Installation DK75 Plumbing 3 05-21-2008 11:08 AM
