-   -   How to remove soldered cap on my bathroom shower flange? (http://www.diychatroom.com/f7/how-remove-soldered-cap-my-bathroom-shower-flange-156758/)
ohman 09-14-2012 03:53 AM
Dear all, thanks for helping out in advance...
I have a old bath that we are trying to get the shower function back. Here is what the bath looks like now (notice the top of the picture there is a shower flange which was painted...):
http://s16.postimage.org/hb9cbvga9/20120906_083938.jpg
It looks like a copper cap was soldered. I have tried to use some tools to remove the cap but failed. Here is a zoomed in photo for the flange:
http://s15.postimage.org/dvoj0uxav/20120906_083948.jpg
My questions:
1. What tool (or procedure) should I use to remove the cap so that I can test it out to see if the pipes still work?
2. If it is not a shower flange, can we still somehow install shower pipes without damage the current tiles??
Thanks!
ohman 09-14-2012 03:55 AM
By the way, found this relevant article online but no conclusive answer:
http://answers.yahoo.com/question/in...7080432AAtcEH5
biggles 09-14-2012 06:47 AM
did the wrench scrape the paint off to show copper put a magnet to it....you might consider drilling a hole in the cap and threading in a fitting to take a shower head pipe.a plumber would open up that area around the cap and swet in a new fitting so you could screw in a pipe out with a chrome plate cover...i would bet that line is active when you turn that middle selection knob diverting the water
allthumbsdiy 09-14-2012 07:00 AM
If I had to guess, that has a short galvanized steel (or brass) nipple with a cap, screwed on to the drop ear elbow (like this - http://www.terrylove.com/forums/show...Drop-Ear-Elbow; also look at step 5 picture from this link http://www.diyadvice.com/diy/plumbin...r-tub-faucets/)
If that was me, I would;
1. Make sure the water is turned off
2. take a sharp utility knife and score around it to break any paint and/or caulk seal(s)
3. use a pair of large adjustable pliers (or small pipe wrench) and gently try to turn it counter-clockwise
4. if that doesn't work, make the opening slightly larger with a utility knife so that I can squirt in some WD-40 and try again
5. if that doesn't work, the nipple might be soldered on to the drop ear elbow. in that case, I would have to heat the fitting with my torch to melt the solder. To do that, I would need to make a large square cutout of the sheetrock to gain some working room.
Good luck
Alan 09-14-2012 10:08 AM
LOL WUT?
:eek::laughing::no:
It almost looks like a pvc cap to me, but the image is not clear enough to tell if it's that, or a really nice paint job.
pwgsx 09-14-2012 11:00 AM
Scrape it and let us know what material is under the paint.
I would cut a inch or 2 all around the cap and see what you got behind the wall and go from there. Then when finished buy a sheetrock hole repair square, drill a center hole and slip it over the pipe and make it flush on the wall, mud, sand and paint and you will never know.
joed 09-14-2012 11:11 AM
I don't see any pictures.
ohman 09-15-2012 01:08 AM
Problem solved. I will post some pictures later. We hired a professional plumber and he used a pair of large adjustable pliers and was able to open it up easily.. and yes there was water coming out!! Thanks for everyone's help.. That only took the plumber about 3 minutes to open it up and he charged $75.. oh boy...
