How To Remove Shower Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2012, 10:00 PM   #1
How to remove shower valve?
My shower has developed a leak and it's been getting worse over the last few months. I've done quite a few plumbing jobs but I can't for the life of me figure out how to remove this stem! This is the original valves from when I bought the house 12 years ago and the first time I've had any troubles.
I've tried pulling and twisting with my vice grips on the plastic parts of this stem but it won't budge. How do I remove this stem so I can replace it?
rabel is offline   Reply With Quote
Old 02-19-2012, 10:04 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Where the plastic stem enters the metal housing you may need to try and insert a flat tip screw driver to try and pry while with pliers on the plastic stem wiggle it side to side pulling out.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-19-2012, 10:06 PM   #3
Experienced
Jackofall1's Avatar
Could you show us the rest of the valve, the parts you removed, but I am thinking that, that insert just pulls out of the valve body.
Mark
Old 02-19-2012, 11:23 PM   #4
Parts
I wonder if I need a special tool or if I should just grab down on this part with my vice grips and pull like mad to rip it out of the copper pipe and hope I can find a replacement part before I need to turn the water supply back on.
Here are the rest of the parts, one together (on the left), the other exploded
and this other photo shows how the plastic "alignment bit" fits inside the copper threads (my hand included to make my camera phone focus properly). The parts available at Lowe's all had two "alignment bits" on each side of the part but mine only has one.
Old 02-24-2012, 06:07 PM   #5
analogmusicman's Avatar
Rewards Points: 560
replace the valve,quit "screwing around"! access behind the shower and take off the wallboard so you can get at it. you'll be glad you did! that's what I had to do.
tnx,
analogmusicman is offline   Reply With Quote
Old 02-24-2012, 06:12 PM   #6
Rewards Points: 12,790
Looks like a cheap valve, most would have used brass.
It also looks like it would unscrew not just pop out. See the threads under those plastic tabs?
Old 02-24-2012, 07:30 PM   #7
Rewards Points: 582
that part just pulls out.. as mentioned small screw driver pry at back of white cartridge...
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
help with how to remove shower drain jcon3678 Plumbing 1 12-13-2010 09:15 PM
Shower valve installation sydni2009 Plumbing 3 09-21-2010 06:04 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 09:19 AM
How to change the shower valve? amdspitfire Plumbing 17 04-06-2008 10:05 PM
